At first glance it appeared to be a KF flange due to the appearance. I measured it with a caliber to be about 25 millimeters so I went with a kf-25. The centering ring is just a tiny bit to big. I attempted to force it in but only got it half way. I stopped trying to force it as I thought any more could damage the centering ring. Can someone please help me identify this flange, or inform me if the vacuum pump or centering ring is bad as it would be very helpful. Thank you in advanced.
[img]/Users/Owner/Library/Containers/com.apple.mail/Data/Library/Mail%20Downloads/86E0C39A-0A43-4B04-ADD1-B7F34B76E5D4/IMG_1642.JPG[/img]
[img]/Users/Owner/Library/Containers/com.apple.mail/Data/Library/Mail%20Downloads/1C3F835D-523F-45B9-B429-514B1DF03F62/IMG_1641.JPG[/img]
[img]/Users/Owner/Library/Containers/com.apple.mail/Data/Library/Mail%20Downloads/7ED13040-2B80-46EF-BF5C-D9428C46641D/IMG_1643.JPG[/img]
Need help identifying flange on vacuum pump
Re: Need help identifying flange on vacuum pump
Oh the pictures didn't turn out very well, here is a repost
https://gyazo.com/592ab17d9d2876a3defc5ce685926365
https://gyazo.com/c9a28a6134a54788653e123460e6b444
https://gyazo.com/b08d8d18654c10ecbc5335f72a7a5fe1
Do the dimensions match anything in this table:
https://hollandaptblog.com/2015/06/15/t ... ion-guide/
or any of the sanitary fitting flanges in the following link? https://hollandaptblog.com/2015/06/15/t ... ion-guide/
It's a kf-25. Just modify the center ring to fit.
Okay, I'll try and sand it down. Are you sure this won't negatively effect the seal?
Boris
Please do not send your pics to an external site to view
use irfanview to resize/ resample to 1024 x 768 so that it loads correctly on this site when you upload your pics
irfanview is free to download
this is important so that others in the future can see what this thread is about
Okay, I'll make sure to use post of of my pictures in the format, thanks for the information.
Dont mess with the flange, just machine down the diameter of the centering ring. Hopefully you can find someone with a lathe. There are some odd ball sizes out there. I just machined out a fitting that was supposed to be kf-25 but a bit small to fit a normal centering ring. I also have a KF40 elbow that is smaller than normal. It has a adapter KF centering ring so you can mate it to normal KF40. Some odd ball stuff out there...
