Vacuum kit suggestions
- Real name: Angelo Romano
Hi I was trying to make fusion in my school and they gave me a 400-500 euro budget for all the vacuum equipment.
My initial aim is Just to make plasma.
They told not to use DIY solutions for the vacuum so I was searching something on eBay.
https://rover.ebay.com/rover/0/0/0?mpre ... 1867425448
This is the vacuum pump that I found in another post on this forum.
And this is the vacuum chamber I've found
https://rover.ebay.com/rover/0/0/0?mpre ... 2033423593
I don't know if the included vacuum gauge is good enough for my aim.
Could you give me some advices and tell me what do you think of this parts?
Thanks in advance,
Angelo.
Thanks in advance,
Angelo.
Re: Vacuum kit suggestions
Sorry if I made this post twice. One of this posts was an error.
I can't delete this post so if you can, do it.
The two stage vacuum pump looks OK. However, the vacuum gauge is not good for the vacuum needed for even a demo fusor.
Thank you.
I think that I'll change the vacuum chamber too withban high vacuum one.
Would this pump also be fine to make fusion or only for a demo?Richard Hull wrote: ↑Fri Oct 19, 2018 3:20 pm The two stage vacuum pump looks OK. However, the vacuum gauge is not good for the vacuum needed for even a demo fusor.
Pretty much demo only. A diffusion or turbo pump is needed after the mechanical pump to warrant a low enough vacuum to allow a significantly pure deuterium gas environment.
Read the FAQs!!!
Read the FAQs!!!
I'm sorry, I didn't see the FAQs at that time.Richard Hull wrote: ↑Sun Oct 21, 2018 11:57 pm Pretty much demo only. A diffusion or turbo pump is needed after the mechanical pump to warrant a low enough vacuum to allow a significantly pure deuterium gas environment.
Read the FAQs!!!
Thanks for the help.
I've read some of the FAQs about vacuum chambers and I think that I'll be making a conflat chamber.
Is there any difference between using a cross or a tee of 2.75"OD?
A "Tee" is generally a three-way and a "Cross" is generally a four way; the difference for fusors is the number of available "ports". One can use either but having extra access ports can be very useful (but does add cost for flanges.) Since fusor's tend to be moderate in vacuum requirements (10^-5 torr is fine), I use o-ring ports to reduce costs and allow me to more easily modify my flanges.
I am currently collecting parts for a new fusor and I have a four-way cross of 2.75 inch diameter. Apparently, these small "chambers" (a "T" or cross) with their sharp corners relax's power supply requirements - low 20 kV appears sufficient for measurable fusion using moderate detector equipment.
Thank you a lot.
Your post was very helpful.
It really great to know that someone already did that.
Bye,
Angelo.
Bye,
Angelo.
