Thank you! That is exactly what I was looking for.
But you're right. I may pass onto this one. Especially since a pump+controller would set me back about $600 total, and since they're so problematic I'm going to stay with the small diffusion pump I have. But I'll save those documents just in case I change my mind at some point.
Noisy Edwards EXT250 Pump
- Real name: Silviu Tamasdan
Re: Noisy Edwards EXT250 Pump
- Real name: David Kunkle
I read a while ago that the smaller pumps like the 50 or 70 lps turbos were a lot more bulletproof and less prone to bearing failure. I believe those are big enough for most fusor chambers. You may want to consider something along those lines.
Ernest Rutherford
Ernest Rutherford
If I can find one. They seem to be fairly rare.
