Jerry,
I probably don't really need to know, but what is IAEBD? Web searches have not been helpful.
[Aside:] Web searching seems to be getting much less likely to find what I think I am looking for than it was a 10-15 years back. The very high Noise to Signal ratio and pay-walling of the good stuff is really getting painful.
Cheap Multi-Pin Feedthroughs?
Re: Cheap Multi-Pin Feedthroughs?
I think it's Ion Assisted Electron Beam Deposition. What that is, could not say.
Ian is right, Ion Assisted Electron Beam Deposition. Where normal e-beam depo just uses an electron beam to melt the material you plan on depositing, Ion Assist uses an additional Ion beam gun to help with the coating. It helps with adhesion and overall quality of the coating. You can also use reactive ions like oxygen to help when doing coatings like SiO2 and some things like cubic boron nitrate can only be formed through ion beam assist.
https://www.unitedlens.com/using-ion-as ... ng-method/
Quick update: some milspec D-sub connectors have a turquoise-green plastic insulation which is (sometime? Always? Only if mfgd by Positronic?) made of DAP, a fairly low outgassing material.
