Pirani Leybold 162 09 Br 1
Angelo Gomes
Real name: Angelo Gomes
Post by Angelo Gomes »
Hi Guys.
Last week I found a Pirani head manufactured by Leybold-Heraeus. It is a 16209Br1 model. Unfortunately, I did not find any manual in the lab and on Google neither.
As you can see in the picture, this head has 9 pin and I would like to use this head in my lab.
Does someone has some info about this Leybold head ? the Pinout ?
Johan Reinink
Real name: Johan Reinink
Re: Pirani Leybold 162 09 Br 1
Post by Johan Reinink »
To be more precise, you found half a pirani head, old Leybold pirani gauges have a blue top with some electronics for the 0 and full range adjustment. The typenumber that should go along with it is 162 02
Angelo Gomes
Yeah, I know that. I just look around and every part of the lab, but did not find any blue plastic cover. This one seems be a replacement head.
As I told before, maybe someone can help with some info about the pins or even the electronics circuit. I think the pinout would be enough as I could make an electronics for it.
Johan Reinink
I have one that probably has a broken filament, I'll post photo's of the inside when I have a bit more time. I also have a few Leybold readouts, I can take photo's of the insides if that's interesting.
Angelo Gomes
Hi Johan.
I appreciate your help.
Thank you.
Angelo
Post by Jerry Biehler »
These old units were notorious for failing from any shock, sometimes even shipping.
