Operating Pfeiffer TC100 Controller
Andrew Seltzman
Real name: Andrew Seltzman
Re: Operating Pfeiffer TC100 Controller
Post by Andrew Seltzman » Mon Mar 26, 2018 2:09 am
McMaster is a US company, they ship fast and have a good selection of products.
What are you using for your vacuum pump, do you know the lowest pressure with the turbo off?
How are you connecting the Yellowjacket to the turbo?
Andrew Seltzman
www.rtftechnologies.org
Jackson Oswalt
Real name: Jackson Oswalt
Post by Jackson Oswalt » Mon Mar 26, 2018 2:48 am
I've used McMaster-Carr many times. They are top-notch suppliers for almost everything. I will send pictures as requested within the next day. The lowest pressure with the turbo turned off is 50 microns due to the leaks. The Yellowjacket is connected to my system with Npt threads, which is connected to the turbo. When the gauge is placed at the head of the turbo the gauge jumps up to atmospheric once the turbo is turned on. Once the turbo is switched off the gauge drops back down.
Andrew Seltzman
Post by Andrew Seltzman » Mon Mar 26, 2018 3:12 am
50 microns might just be the maximum vacuum of the backing pump. It's more then sufficient to pack a turbo pump. Jumping to atmospheric when the turbo is switched on is very unusual, I suspect a problem with the gauge.
I would recommend an MKS 901P vacuum gauge instead
https://www.ebay.com/itm/MKS-901P-901P- ... Sw1gRaeOIg
Andrew Seltzman
Post by Jerry Biehler » Mon Mar 26, 2018 5:19 am
You may need a better gauge, what are you using?
Jackson Oswalt
Post by Jackson Oswalt » Mon Mar 26, 2018 8:51 pm
I agree, I definitely need a proper gauge, not an HVAC gauge. How do I find the pin out for this gauge? Is there a proper controller? How do I read the pressure off it?
Thanks!
Tom McCarthy
Real name: Tom McCarthy
Post by Tom McCarthy » Mon Mar 26, 2018 9:46 pm
The 901P is well worn and has been used by a couple of guys:
http://fusor.net/board/viewtopic.php?f= ... 01p#p78358
http://fusor.net/board/viewtopic.php?f= ... 01p#p78768
You'll find more on it if you use the forum search
Google is generous too:
http://www.idealvac.com/files/manuals/901manual.pdf
Post by Jerry Biehler » Tue Mar 27, 2018 1:46 am
Ahh, I have had some thermoucouple gauges act weird when they get below their lower limit. These HVAC gauges were never intended to see anything that a Turbo pump runs at.
You can get away with one of the 901P's but if you really want to see what the turbo can do you need an ion gauge. I have gotten several PKR-250 and 251 wide range gauges over the years off ebay. I dont think I have ever payed more than about $100 for one, Varian and other also make versions. Though you just cant go wrong with a standard hot ion gauge. I have a couple analog controllers lying around that I dont need any more...
