TMH-260 Turbo
Gustavo Cervantes
Real name: Gustavo
TMH-260 Turbo
Post by Gustavo Cervantes » Thu Apr 05, 2018 1:46 am
Hi everybody im new to the forum,
as you can imagine im currently trying to build a vacuum chamber to gain konolowege and in the far future turn it into a fusor.
Last weekend i managed to get hold of a pfeiffer TMH-260, very dirty and with a broken ceramic bearing but still i think is reusable
You can see the only damage in the rotor is a small bumb in one of the blades.
Im coming to you asking for imformation about the driver, conection voltajes etc etc,
BTW, English is my second languaje so dont hesitate to correct me.
Re: TMH-260 Turbo
Post by John Futter » Thu Apr 05, 2018 6:55 am
gcr100
I would fix your login name as per the rules PDQ
You should have also introduced yourself in the correct forum
Re: TMH-260 Turbo
Post by Jerry Biehler » Thu Apr 05, 2018 7:21 am
I hope there is more of it than just that...
Re: TMH-260 Turbo
Post by ian_krase » Thu Apr 05, 2018 4:49 pm
Bearings likely available from Alpine Bearing. Expect to pay hundreds of dollars.
You'll need to balance the rotor. There are some cheapish tricks you can use for this.
Re: TMH-260 Turbo
Post by John Futter » Thu Apr 05, 2018 6:57 pm
When you registered you clicked to accepted the terms given on the 1st registration page:
Fusor Forums - Registration
This contains the same as what is listed here:
Board index - Announcements - Announcements and Site Administration Topics
Fusor.Net Policies and Procedures
and specifically The Rules: #1
but you failed to do that. Please change your username to comply.
Changing your Username
The forum rules require you to use your full name as your username. Many people miss that and create an account with some tag name.
This forum does allow you to change your username. I just tried it and it seems to work for me.
Here's how:
Login to the board
click your current username in the upper-right of the main page and select User Control Panel from the pull-down
In the tabs at the top, select Profile
At the left column, select Edit account settings
Edit the Username: field to be your full name
Type your password in the Current password: field (near bottom of page)
Click Submit button at bottom
Note: After you change Username, the new name becomes what you use to login to the Forum. Your password should remain the same.
I also suggest adding a Location to your profile. It often helps to know generally where a member is in the world while responding to them. I have used my City and State, but if you are worried it could be more general -- just State, something like Central USA, just your Country is better than nothing.
Adding a Location
(Skip the first 3 steps if you are already in the Profile section from doing the Username update.)
Login to the board
click User Control Panel near the top of the main page
At the left column, select Edit profile
Edit the Location: field
This Location information will appear in the right column, under your name, when you post.
thanks to Rex for this
Gustavo Cervantes
Real name: Gustavo
Re: TMH-260 Turbo
Post by Gustavo Cervantes » Sun Apr 08, 2018 3:51 am
thanks i think its fine now, does anyone here know the pinout for this particular pump?
Joshua Turbyfill
Real name: Joshua Turbyfill
Re: TMH-260 Turbo
Post by Joshua Turbyfill » Sun Apr 08, 2018 7:42 pm
Hi Gustavo,
Finding the correct wiring can be a real pain - also it might need 3-phase power to run. I tried this with my TMH pump and ended up just resorting to buying the controller. You might end up having to do the same.
I've attached the pump's manual, that might be of help to you.
Also, unless you've just disassembled the pump its missing atleast the stators and the rotor housing, maybe more.
TMH_TMU_260_MANUAL.pdf
(441.82 KiB) Downloaded 119 times
Gustavo Cervantes
Real name: Gustavo
Re: TMH-260 Turbo
Post by Gustavo Cervantes » Tue Apr 10, 2018 2:44 am
i have read a the manual a few times before posting here, but i cant fin the pinout anywhere, the point of that is to make the controller (i have a little experience making triphasic motor controllers for BLDC motors), but without knolowedge about the array of coils i dont thing i can.
Re: TMH-260 Turbo
Post by Jerry Biehler » Tue Apr 10, 2018 2:52 am
A lot of pfeiffers are two phase. You will have pins for that, an eeprom, and a temp sensor. I am not sure if they have halls.
Gustavo Cervantes
Real name: Gustavo
Re: TMH-260 Turbo
Post by Gustavo Cervantes » Tue Apr 10, 2018 3:07 am
At least 6 pins have continuity between them .5 ohms or so, this confuses me a little, because not all 6 have the same resistance, probing with the meter some have .2 ohms.
I dont have an lc meter to acurate measure the inductance of the coils, may be the best idea is to disassemble the pump, pull out the stator coils and see how its arranged.
