50kV Supply
Re: 50kV Supply
Hello,
Finally I received my unit. Now I am working on the driver.
I would appreciate your comment on my design. This is based in Joe's suggestion (http://www.loneoceans.com/labs/sstc2/), and Gao Guangyan's project.
The output will be plugged into the unit transformer.
I am still working on the frequency generator to control the IGBTs.
Thanks for the help.
Regards,
Cristiano
Regards,
Cristiano
- Real name: Chris Giles
Re: 50kV Supply
HI Cristiano
I recommend that you purchase one of the control boards from the seller and use that as a start. Coupled with the HV box it makes a complete Glassman ER PSU minus the front panel components. It has a driver similar to your sketch. You can start from that and then try to hack it to get higher output.
If you choose not to, you can still refer to the schematic for it. Regarding your schematic, you should use a bridge rectifier, and also you would not need a Variac if you use a standard PWM controller/driver IC where you have shown "frequency driver".
Regards
Chris
Regards
Chris
Re: 50kV Supply
Hello Chris,
Thank you for your feedback. I will check this board with the seller.
I completed the schematic, using my initial design. Now I need to figure out the value of interrupter's resistors and capacitor. I think 25 kHz and 40% duty cycle is a good start and it will not stress the unit.
Please fell free to comment and give any suggestion.
Regards,
Cristiano
Regards,
Cristiano
- Real name: seamus
Re: 50kV Supply
how many mA should the 50kv transformer be rated at?
im a still learning and planning on building my own fusion reactor.
Re: 50kV Supply
Seabird, your two first posts seem very uninformed and possibly troll-like, but I won't give any details why until you fix things to become a valid user.
(Posting my new-user reply again.)
When you registered you clicked to accepted the terms that were given on the 1st registration page:
Fusor Forums - Registration
That page contains the same rules as what is listed here:
Board index - Announcements - Announcements and Site Administration Topics
Fusor.Net Policies and Procedures
viewtopic.php?f=47&t=10508#p69690
and specifically The Rules: #1
The forum rules require you to use your full name as your username. If your name is John Smith, your UserID (i.e. login handle) must be John Smith, or John_Smith. This is the name that will appear in the forum listings. “JSmith” or “JohnS” or “JS997” or “handles” like “MrFusion” or “ProtonBoy” are NOT permitted.
Also there is: The Rules: #2
New members are required to introduce themselves in the "Please Introduce Yourself" forum prior to posting elsewhere on the site.
You have not complied. Please change your username to comply.
Changing your Username
Here's how:
Adding a Location
(Skip the first 3 steps if you are already in the Profile section from doing the Username update.)
Don't forget to make your "Please Introduce Yourself" post too.
Here's how:
- Login to the board
- click your current username in the upper-right of the main page and select User Control Panel from the pull-down
- In the tabs at the top, select Profile
- At the left column, select Edit account settings
- Edit the Username: field to be your full name
- Type your password in the Current password: field (near bottom of page)
- Click Submit button at bottom
- Note: After you change Username, the new name becomes what you use to login to the Forum. Your password should remain the same.
Adding a Location
- click User Control Panel near the top of the main page
- At the left column, select Edit profile
- Edit the Location: field
- Mark Rowley
- Real name: Mark Rowley
Re: 50kV Supply
His question is also not pertinent to this thread and furthermore the answer he seeks is easily found in the FAQ's. Providing he complies with the registration rules, answering his question will serve to skew / hijack the linear flow of Joe's post.
- Real name: seamus
Re: 50kV Supply seamus sullivan
ok sorry
i have fixed that and put in my real name and my about me.
what should my power supply be rated at?
how many mA and kv should it be set at?
Re: 50kV Supply
Fusion power supplies are not set at any voltage or current. Instead they must be totally variable from 0 volt to a maximum determined by the user. Demo fusors are easily run by oil burner ignition transformers controlled by a variac. They are typically rated at 10kv @ 20 to28 ma. A neon sign transformer is more often used in the 12kv to 15kv range and rated at 30ma. High voltage diodes are needed to turn this into DC.
All of this related to a demo fusor is in the FAQs which it is now obvious you have not read at all. Demo fusors do not do fusion....
Serious, real fusion fusors demand a minimum of 30kv @ 30ma capability or more. This separates the men from the boys. Top level fusors use supplies that are capable of running well over 40kv @ 30ma.
Again, all of this is in the FAQs....Read them....
- Real name: seamus
Re: 50kV Supply
ok thanks for your help. i will read the FAQs. I just recently registered and don't know a lot about the site.
- Nicolas Krause
- Real name: Nicolas Krause
Re: 50kV Supply
I've finally gotten around the opening up my Glassman 50KV supply, and was reviewing this thread before beginning the conversion work for my fusor. Unfortunately a number of photo links in this thread appear to be dead, I was hoping Joe had some backed up and would be able to repost them!
- Bob Reite
- Real name: Bob Reite
Re: 50kV Supply
You don't need 30 mA. I have achieved measurable fusion at 40 KV at 7 mA.
Re: 50kV Supply
Nicolas,
Per your, "opening up my Glassman 50KV supply." I'm not sure what that means. What exactly do you have?
The aluminum box that Joe tipped us off to is part of a rearranged custom design based on a
Glassman ER50N6 0-50kV 0-6mA supply. That aluminum box has the high frequency transformer and a multiplier section. To make the box work it needs a driver board. Joe made his own, the full design was never shared. In the TSA-style x-ray scanner that these came from there was a main board almost exactly as in a Glassman ER supply. The ebay seller was offering a very price-reasonable package with the aluminum box, the main board, and connecting cables.
Chris Giles is the only one I heard from that went for that deal. (Other than me.)
I think I have worked out all the details one might need for a standard ER supply or the variations that this scanner package used.
So if you say what you have, and it is some form of ER that I understand, I can probably point you at an info package with all the details to make it work. If you got one of the aluminum boxes but not the main board, then you are missing the whole driver system.
Oh, and with Joe's driver that he designed, I think he pushed the (aluminum box) transformer and multiplier a good bit beyond the 300 W output specs of the ER50N6.
Re: 50kV Supply
Hello,
At that time I bought one of this box. Indeed it didnt come with the driver.
If someone develop a driver for this supply, I am interested.
Regards,
Cristiano
Regards,
Cristiano
- Nicolas Krause
Re: 50kV Supply
Hi Rex,
I have the same box purchased by Joe, it's the AHV1IRT50N06, it requires the driver circuit. I'm planning on making my own, but I was hoping to see the arrangement in the box that Joe had built just to give me an idea of how he'd solved the problem. Unfortunately the photos have disappeared due to the site migration.
Re: 50kV Supply
I have this picture from original post:
- Nicolas Krause
Re: 50kV Supply
Thank you Cristiano!
