I’m using a transformer that came out of a General electric x ray head. When I was pouring out the oil it was black. The x ray transformer seemed fine. I saw no breakdown or discoloration. Could the source of the discoloration of the oil be PCB's?
Black Mineral Oil
- Real name: Alex Peterson
- Real name: Massimo Cassano
Re: Black Mineral Oil
Black? I've got a similar xrt from a gender x1000 and oil was brown and as far as i know that oil does not contain pcb's, when you enter in contact with them you get some pretty bad looking acne and it was not the case
A photo of the oil pouring from the head
alot of x ray heads have golden brown mineral. it seems normal for yours. But, my oil was pitch black and had a really foul smell. I was just concerned about PCB's.
Can't help you then, good luck anyway
There isn't any way to know for sure without a chemical test. However, according to Wikipedia GE had a stinky PCB oil -
"Pyranol/Pyrenol, Chlorinol (widely used in GE's oil-filled "chlorinol"-branded metal can capacitors, detected by a pungent characteristic odor released by them (especially when they fail) in appliances/consumer & commercial electronic units & motors that utilized them from the early 1960s-late 1970s such as many A/C units, Seeburg Jukeboxes & Zenith TVs)"
I have no idea what color it was, but considering the head was a GE (from the affected time period?), I'd take extra precautions to avoid more exposure with that oil.
Hi Jim, thanks for the data, I didn't know that, luckily mine was manufactured in the 87 and by that time i think gender and ge were two different companies and as far as i know they didn't use pcbsJim Stead wrote:There isn't any way to know for sure without a chemical test. However, according to Wikipedia GE had a stinky PCB oil -
- Rich Feldman
- Real name: Rich Feldman
Did you mean Gendex where you wrote Gender, as a maker of x-ray equipment?
Here's a detailed forum discussion about PCB's. Some contributors are legendary in the HV and tesla coil world.
http://www.pupman.com/listarchives/2002 ... 00811.html
This reference says that black color just means the oil is probably old and bad, not that it has PCB's: http://www.powersubsvcs.com/images/PSS% ... ummary.pdf I have one old capacitor that says Pyranol on the label, and has a tiny leak, and the resulting oil spot is colorless.
Here are a couple of trivial tests that would tell if the x-ray head was most recently filled with Aroklor etc.
PCB's are denser than water; hydrocarbon oils are less dense.
PCB's are non-flammable and hydrocarbon oils are flammable. That difference saved lives.
Of interest today are mixtures that contain traces of PCB's ( 1 to 500 ppm ).
That's the range covered by products like Dexsil Chlor-n-Oil test kits.
PCB's are often found at those levels in reprocessed / re-used oil. It would be too expensive to completely purge transformers and oil handling equipment when changing between fluid types. IIRC, below 50 ppm you are allowed to put a "non-PCB" sticker on the device. At 500 ppm you probably should not ingest the fluid, live over soil that's soaked in it, or handle it every day at work.
