I designed a quick/simple analog interface to control the Spellman DXM power supply.
The operating current and voltage can be monitored through the Ethernet/Java app interface, but the values can be smoothly and continuously changed with this little board.
The board can be found here: https://oshpark.com/shared_projects/fwsaMyna
Documentation attached. (Thank you to Dan Knapp for publishing his schematic - download/file.php?id=11302)
Simple Analog Spellman DXM Controller
- Garrett Young
- Real name: Garrett Young
- 2Layer.PDF
- (263.9 KiB) Downloaded 347 times
- Garrett
