Precipitator power supplies?
Re: Precipitator power supplies?
Post by ian_krase »
You're saying that to use this in a (conventional) fusor one would ground the, well, ground, and then use the negative 30kv output to drive the grid (And yes, that does sound rather low, and low current to boot)
Is that correct?
This suggests that an unconventional system (i.e. one with different grounding requirements) might use both ends properly?
Real name: Dennis Brown
Post by Dennis P Brown »
To use this power supply for a real fusor one needs a couple of things (previously mentioned in this thread.) First, one MUST get a negative output from this wildly swinging AC source so diodes (at least two but a bridge could also be done) are required; and second, a ballast resistor to prevent a massive over current flow when a plasma first ignites. The resistor issue is well covered in the FAQ's on power supplies. Of course, the diode as you may or may not know is seeing a higher peak voltage than the max rated voltage for the supply (for any AC powered device) so these diodes must be rated for the higher voltage with some safety factor. As for grounding, that is an issue but that depends on the supply - the fusor's chamber itself (generally) is the main ground. Grounding a flyback isn't a straight forward thing to do. Yes, the case should be grounded but most flybacks I've seen (not too many, however) float. Other's can weigh in on that specific topic.
Aside: don't underestimate the lethality of flybacks - even if the unit can't do fusion that PS will be deadly with anywhere near that power. Use proper cables and follow all standard HV safety protocols.
Post by Jerry Biehler »
Wildly swinging AC source? This unit should be DC out. Precipitators dont work on AC. The negative size goes to the wires in the collector and positive to the plates where the particles are collected.
Those transformers probably have diodes built in.
Post by John Futter »
Ian
No you would connect the positive output to ground and the negative output to your grid, but because of what i said earlier this may compromise
creepage distance on the PCB and the flyback transformers winding to core
they certainly dont cost much so it is worth a try
Shireesh Apte
Real name: Shireesh Apte
Post by Shireesh Apte »
This is the high voltage unit I have recently used to generate a plasma at 100 microns pressure. If the specs are to be believed, this unit may be capable of (mid-range) 30 KV and 10 mA. By all accounts, from whatever I have read on the FAQ posts, this should be good enough to detect fusion. By the way, my plan is to use a silver sample contained in a moderator (i.e a water bath) so as to allow the (slower thermal neutrons) to convert part of the silver to cadmium and emit gamma and x rays that I can detect with a Geiger counter.
I will of course devise methods to measure the actual voltage and current for the fusor part of my project.
Thanks and Best regards,
Shireesh Apte
High Voltage Electrostatic Precipitator Power Supply with 400W 60kV
Specifications
1.Input voltage AC160V-260V
2.The output voltage is DC5KV-60KV, adjustable speed
3.Output current 8-12mA
4.Size: 230*180*80mm
5.Weight 1.78KG
Finn Hammer
Real name: Finn Hammer
Post by Finn Hammer »
Gods speed to you, for testing this supply.
Those of us who has had access to better supplies like Spellman et al will tend to disbelieve the suitability of it, with regard to delivering, in particular, the voltage. I doubt it too, due to experience with similar supplies, where corona issues, and tracking, put an end to the transformers. But this is speculation, whereas nothing beats hands on experience, and you are getting it.
Looking forward to read your results.
Cheers, Finn Hammer
Those flybacks look like the type with diodes in them. If those are repurposed TV flybacks, the voltage out is positive. I suppose a manufacturer might have special negative polarity diodes potted into them. Like Finn, I hope you efforts pay off. Keep us in the loop and report your efforts as they go.
Shireesh Apte
Thanks Finn, Richard,
My students rigged the potentiometer knobs with a short piece of tubing into which glass rods were inserted (attached). These glass rods project out of two holes in a wooden enclosure made from waste oriented strand board that I scavenged from Lowes. I will post a photograph next week. I am a novice at circuits (as with almost everything else - as I have found that Knowledge is essentially a black hole) but so far- my method has been NOT to touch ANYTHING once I have it fired up. I am learning as I go - I realize this is dangerous; but as the man said - D-day might have been under entirely different circumstances had Eisenhower waited for the weather to clear.
The safety of my students is my primary concern and I take that very seriously - even with the more zealous (Instant gratification) types - as I seem to have this year helping me on my 'Star-in-a-jar' and 'fusor' project.
I will post detailed pictures of my set up in the 'construction' part of the forums next week.
By the way, my expertise (such as it is) lies in the field of Pharmaceutical excipients -having worked for over 20 years in the pharmaceutical industry - and you can find many of my manuscripts in the peer-reviewed journal I run: https://jefc.scholasticahq.com
Thanks again.
Best,
Shireesh
I have my doubts that 30 kV at 10 ma is enough to activate Ag that is detectable (if that supply really is providing enough average power to really provide a full 300 watts - as I said previously, being an AC driven system (the flyback), the output current is varying a great deal so the real average power could be less than that simple calculation would lead one to believe.) That said, since you came this far, might as well try it. However, if you are unable to detect activation of Ag, that does not necessarily mean you've had no fusion (if your real power is three hundred watts you likely have some not insignificant level of fusion.) So, don't be discouraged. Detecting neutrons is not easy.
I say this because I can easily detect fusion neutrons using my Russian boron-based gas filled tube and my fusor power is 1500 watts (or more) but I can't activate Ag enough to detect it using a Geiger tube. That could, partly be geometry issues but still, in the FAQ's, three hundred watts is not considered enough to activate Ag, if memory serves.
That all said, how are you going to measure both the voltage and current of that power supply? Knowing those values is essential to determining if the supply is even capable of being used for fusion and is delivering those values to the plasma. I ask this because determining that this flyback based supply can deliver that level of power would be a very useful contribution to this forum.
I may have forgotten if you already talked about this topic but what type of chamber are you planning to use? Saying "star in a jar" is not reassuring ... if you get my drift.
Finally, I know only what you posted and what the picture shows about that power supply - the two input points (if they are) then require a single phase source, which means you need 208 AC single phase - that is not routinely available. Three phase 220 does not appear to be supported by that supply - hopefully, that isn't the case. But since you indicate you know little about electricity, that is a rather critical issue if you plan to power that specific supply (single phase 120, if the documentation is correct, will not be sufficient.) Maybe check the instructions and confirm that input issue.
Last edited by Dennis P Brown on Mon Oct 30, 2017 7:02 am, edited 2 times in total.
Finn Hammer
Shireesh,
For your consideration, here is an image of the voltage divider I use for my high voltage work. It is shown hooked up to another Precipitator supply that I am evaluating for a precipitator project I am associated to.
It is a 20.000 : 1 divider. The high voltage resistors are 1% 20Mohms, 10 of them, the bottom resistor is 10Kohm.
The resistors are terminated in 6mm brass balls, and there are potential rings at the top. I should have completed the rings all the way down, but got distracted.
It is fine for DC work, but lacks compensation for AC work, where a sophisticated arrangement of parallel capacitors would be needed.
Feel free to replicate, It will serve you well.
Hope this helps
Cheers, Finn Hammer
Shireesh Apte
Thanks Dennis, Finn,
Yes, the precipitator does take a 220 V input. I have a voltage converter attached to the Variac into which I plug in the precipitator input (see pictures). I will research the silver to cadmium transition further as regards the minimum detection threshold. Thanks Dennis for posting your measurement apparatus. I will research this further.
Silviu Tamasdan
Real name: Silviu Tamasdan
Post by Silviu Tamasdan »
Um that up-converter is rated for 50W.
Based on some previous experience I sincerely doubt it's even able to sustain that for more than a few minutes at a time.
It's extremely under-powered for your purpose.
Remember, the strength of a chain is not greater than the strength of its weakest link.
Silviu Tamasdan is correct; your output will be 300 watts (assuming 30 kV @ 10 ma), so the input power must exceed that by a good bit, too. Power out can never be greater than power in ...that is, unless one has achieved economical fusion ...sorry, had to get that last part in.
Your approach makes excellent sense to test the device's operation but you must keep the current drawn by the HV system very low so as not to blow that step up converter. So a powerful and sufficient ballast resistor is essential before hooking this power supply up to create a plasma. That should allow you to test the device at 1 or up to 1.5 ma. If you get close/hit 2 ma, that will exceed that voltage convert's limits. Remember - the power rating of a device is an absolute limit that rarely can hold up long.
Along these lines, a measurement of the input power (easy - any voltmeter and a decent amp gauge can handle) will tell you a lot. If the HV system is running all out and the input voltage/current are under 200 watts, the supply will never do detectable fusion (say, 200 volts in, @ 10 amps to that HV system equals 200 watts going in and that means you are not getting even 200 watts out (remember, voltage devices never convert perfectly; they always suffer power losses.)
It appears from the pic that all the flyback's are wired such that there is a single main "output" wire? The red one (and the black is, ground)? How do the other flyback's connect together via that single output? Maybe a lower board picture will clarify that issue for me.
Again, your making progress but there will often be issues that create problems that prevent getting to where one thought ...I have learned this all too often in getting my fusor to work (lol.) Keep at it. You have gotten along very well considering your starting point.
AS I tell new people here all the time - be very careful with high voltage power systems! You get no second chances so they must be as fool proof as possible. One time not thinking and if the supply is lethal, then that person is dead. Be safe and exercise caution: especially if anyone else is around who does not understand the danger. Never allow anyone to interact or run a deadly high voltage system that isn't fully knowledgeable of the dangers and knows how to be safe around these potentially lethal systems.
This brings us to x-rays; a 30 kV, 10 ma source can be a significant x-ray hazard. One cannot expose either one's self (if one is sane) and most certainly not innocent bystanders to dangerous levels of radiation. So, that is a safety issue you must address now before you operate that power supply in a manner that can create x-rays - maybe it will turn out that the supply is too weak to be a danger but if it does put out a few milliamps in the 20+kV range, it is a radiation hazard when used in a fusor arrangement and you MUST follow all local laws/regulations for radiation since you are operating this in a public institution.
The last part of Dennis' post regarding radiation should send one screaming to the FAQs in the Radiation forum. Read and learn.
Silviu Tamasdan
Just as a side note, it seems to me that the way those flyback transformers are used is inefficient. Guess it's because they used off-the-shelf parts. I've been doing some calculations lately related to my own power supply woes (no way to find an adequate high voltage transformer so I'm designing my own high-frequence power supply with ferrite core). The power supported by a ferrite core increases with the square of the core area. Having 4 discrete transformers each with its own secondary winding in parallel is less efficient (at least for cores over a certain size) than sticking the cores together and winding one secondary over all of them.
(In my case I'm looking at some cores with an area of 16cm2; each core would support transfer of around 180W, but 3 stuck together to form one core with the area of 48cm2 they would support over 1.5kW)
Shireesh Apte
Thanks Silviu, Dennis
The 50 Watts was enough to generate plasma. It will obviously not do fusion. Having obtained a plasma (and hence some funding - which I desperately need) based on proof-of-concept, I can now turn my attention toward fusion proper. Before I abandon the electroprecipitator, I will measure the output once I have the requisite input device. I am less concerned with how efficient (or inefficient) the transformers themselves are so long as they output the required volts and amperes needed (considering that my end result -fusion - is itself extremely inefficient with this experimental setup).
I will post all the hardware I have acquired in the 'construction' part of the posts.
By the way, I aim to find out to what vacuum I can reach with my plasma supplies and two rotary vane pumps 1]connected in series and 2] connected in parallel. I know there is a probably a lot of literature that already exists on this. However, since I have the supplies and it is an easy enough experiment; at a minimum; it will be experience gained.
Best,
Shireesh
Silviu Tamasdan
With rotary vane pumps connected in parallel, I don't think you will see a higher vacuum than with one pump, but you will probably achieve that vacuum faster. With pumps in series, I think that you will have issues with oil from the first pump being sucked into the second one. These usually aren't designed to have anything connected after them.
Post by ian_krase »
Don't connect rotary vane pumps in series. Bad idea.
There's a kind of mechanical pump meant to go in series with a rotary vane pump, called a Roots Blower, but you probably don't need one and they are usually huge industrial devices any way.
Agreed that series with your pumps isn't a good idea; parallel, while it will make things a bit faster that arrangement will not get a system any lower. If the pumps can't get down below 50 microns (the least for a DP to operate in a fairly safe manner), then they simply aren't sufficient for the job; however, I still believe your pumps aren't the issue but the connectors you use for both the pumps and that vacuum gauge (with its highly questionable connector methodology.) Get a micron gauge that uses standard vacuum connectors - KF stuff isn't expensive if one looks carefully on ebay and explores what surplus companies offer. One can get absolute steals if one is careful.
No fusor project can get off the ground until a viable vacuum system exists - period. Focus on that; otherwise, you are wasting resources.
For instance - you need to convert your vacuum pump to some type of KF fitting. Here is a possible fitting type for your pump:
https://www.ebay.com/itm/1-4-Male-BSPT- ... SwPDZZdDK-
This is a new adapter and very low cost; yes, you will then need a TC gauge (or similar) with a matching KF fitting but that is how one starts to build a leak proof, usable fusor vacuum system. Think this out before buying more power supply's, or a DP or deuterium gas.
People have connected rotary pumps in series, you can get a lower vacuum. How much, who knows. You wont hurt anything.
Parallel will get better throughput.
Just get a good vacuum pump to start with. I have a friend that is selling a whole bunch of nice adxien (alcatel) pumps. Not cheap, but a good price.
