Project sharing: How to build a ZVS high voltage arc generator
Posted: Tue Feb 27, 2018 1:05 am
by Joshua_S
material requested:
Two large U ferrite cores
A large number of enameled wire
PVC tape
Pipe-thread Teflon tape
Pouring sealant of thermal conductivity
Utility knife
Glue
electric wire
And a lot of time
Winding the coil
First, wrap a layer of insulating paper on the ferrite core, and then start winding the coil around 20 circles per layer.
Leave a section at both ends, not too close to the edge.
Glue it around and then wrap a layer of PVC tape and insulation paper.
Do it over and over again.
Leave the center line a little longer, and don't break it.
A total of 40 layers is a big project and the voltage then we get is about 30KV.
Weld the ends of the enameled wire to the electric wire and pack it with PVC tape.
Wrap the whole coil with the pouring sealant. This will be effective against leakage of electricity and also waterproof.
Wrap around a primary coil, and two electric wires(8+8) are what we need.
Put the coil go through those two large U ferrite cores and then it is finished.
What we finally get is very beautiful and it's not that difficult to make, right?
Zero voltage switching is essential for achieving high working frequency, but we all should be mindful of it's limitations, it's potential impact on circuit operation and reliability when it enter hard switching mode, and use these knowledge to select suitable MOSFET or IGBT for it's applications. There have been successful cases of making a ZVS using IGBT, go ahead If you are interested and pick up something about What is the Difference Between MOSFET and IGBT(http://www.apogeeweb.net/article/66.html).
Thanks for you time.
Re: Project sharing: How to build a ZVS high voltage arc generator
Posted: Wed Mar 21, 2018 10:41 pm
by Adam Binns
this is quite interesting,
do you know the current output of a device like this and what input are you using?
Posted: Thu Mar 22, 2018 1:41 am
by Rich Feldman
Welcome, Joshua.
Nice pictures of coils. Since you took the trouble to embed them, applause for using appropriate-sized images instead of "maximum camera resolution".
Can you tell us the arc voltage (not the open-circuit voltage)? Arc current? Frequency? This is a place where you could get advice about how to measure them.
The post belongs in New User Chat Area, like it says in the full name of the Construction/Technical forum you chose.
Guess it's my turn for Rules Police duty. You're expected to start with a personal introduction in the Please Introduce Yourself forum, as stated on the page where you registered. And your username is wrong unless your last name is the letter S.
