Another gun I put together
Re: Another gun I put together
You might also want to look at Tungsten-Rhenium, which has almost as high a melting point as Tungsten, but is a whole lot easier to machine. This also may go for spot welding, too.
Hi Phil:
Replicating the gun you gave me is a fun thing!
Ok ...How did you mount the BeO tube in the conflat nipple?
Very pretty welding here!
Or soldering?
Happy Fusoring!
Larry Leins
Fusor Tech
Or soldering?
Happy Fusoring!
Larry Leins
Fusor Tech
Hi Phil…
I saw your post on this forum, and I must say that I really am impressed with the ion gun that you built! I am interested in building a linear accelerator, and wondered if your ion source would be appropriate for that use. A linear accelerator uses a very hard vacuum as opposed to a fusor, and I am not sure if that would be a factor with this. Another question that I thought of is would this device work with heavy gasses, such as Xenon? Finally, do you make your ion guns available for sale? I do not have any machining skills, and I must say that what you constructed looks like it would take a master machinist from Germany to make.
I have a long way to go with my project, and so far I have been working on the vacuum system and a voltage source (CW voltage multiplier).
Email me privately if you want.
All the best and 73,
Joe Herdler, KB0TXC
Joe Herdler, KB0TXC
