Ivan is correct. U of W found that the embedded target fusion in a fusor lagged far behind the IEC transparent grid equivalent.
I have that report printed out and in my library.
Ion guns and thick targets.
Re: Ion guns and thick targets.
Hi Larry,
I was just browsing through some older posts and I noticed your reference to the Gow & Ruby ionizer but I was perplexed by the subsequent comments on filaments, RF, etc. Is this ionizer the the simple cold cathode ring magnet device that forms the anode region or something else?
Very good info on the thick Ti target.
Steve
Steve
- Doug Coulter
- Real name: Doug Coulter
Thanks for noticing this and bumping it up Steve - it's relevant to what I'm doing myself now.
Other sources I have indicate he should have been more patient and that neutron yield would have gone up substantially with a couple more days of pushing D into the target.
The fast-neutron guys use thin targets for a completely different reason. They want the reaction energy to be tight, with few low energy stragglers that have lost energy penetrating the target with no reaction yet. And for better cooling. For just making neutrons, a thicker target should be OK as long as you don't hydrate it so well it turns to dust - the other advantage of a thin target is a substrate that rejects hydrogen and doesn't get brittle.
Most of the use of self replenishing targets I believe is in sealed neutron tubes where you also don't want a lot of "sponge" to soak up the deuterium or tritium. There's already enough that they need to have reservoirs, usually a zirconium filament, that can be heated to evolve the isotope and keep the tube at the correct pressure.
While I don't have anything set up for neutron production at the moment, might rethink that situation a bit. Got my hands pretty full with pulse devices and educational stuff.
Steve
Steve
- Real name: Frank Sanns
Larry had a medical situation back a number of years ago so he he no longer has the ability to post on here and last I heard, he did not have access to read it either.
Frank
Frank
Very sorry to hear that. Thanks for letting me know.
Steve
Steve
D embeds in all metals as hydrogen loves metal lattices. In a fusor, there is embedment in both walls and inner grid. Thus, the fusor does do target fusion among its many and varied fusion modalities. It may rate as one of the most numerous varigated fusion event devices known!
