Problem with Canberra Series 30
Re: Problem with Canberra Series 30
Postby dario_tortato » Sun Feb 12, 2017 3:54 pm
Ok, I solved the problem, I'm just stupid. To give the supply voltage in the safety, at the instrument under test, I use a 230/230 isolation transformer and a variac with which the straight edge voltage, starting from a hundred volts, and if there are no problems the increased up to the operating voltage.
This caused the flickering image, I connected the device directly to the supply network, and now the picture is still beautiful and everything ok.
dario_tortato
Real name: Dario Tortato
Postby richnormand » Sun Feb 12, 2017 8:27 pm
Nice to hear, congrats.
I guess your next steps is to test the ADC in PHA mode and see if the front-end is OK.
Do you have a scintillator/photomultiplier with a HV supply handy?
richnormand
Real name: rich normand
Postby dario_tortato » Sun Feb 12, 2017 8:37 pm
Tanks. Yes, I've this:
Dario
dario_tortato
Postby richnormand » Mon Feb 13, 2017 11:33 pm
Very nice indeed! You seem to have a very nice lab.
Please post your test result once everything is working well.
You could use the K40 1.46MeV line from a box of salt substitute from the grocery store.
richnormand
Postby dario_tortato » Tue Feb 14, 2017 9:27 pm
Tank you, no problem, I've many sample source for test. This isn't my first MCA :-)
I hope the weekend to do some testing and then post the results.
Dario
dario_tortato
Postby dario_tortato » Thu Feb 16, 2017 8:57 pm
Hi, I did a little test of the instrument, it seems okay.
I put the picture of a pair of spectrum.
Dario
dario_tortato
Postby dario_tortato » Thu Mar 16, 2017 10:30 pm
After the work of arrangement, some aesthetic restoration:
Dario
dario_tortato
Previous
Return to Neutrons, Radiation, and Detection (& FAQs)
Who is online
Users browsing this forum: Google [Bot] and 1 guest
