Thanks go to Steve Hansen of the Bell Jar for this tid-bit.
http://scitation.aip.org/content/aip/jo ... alert=true
Before we all freak out and go nuts over this, there are and will be zero avaialble sensors of this type for a number of years that you and I can afford.
New neutron detector
- Real name: Louis Haeberle
Re: New neutron detector
If anyone's interested, I attached the article PDF. Large-area, non-coated photodiodes like the ones they used are readily available:
Working in a dry glovebox is challenging, but less so than working in hard vacuum... and if it's possible to acquire deuterium gas, it's no trouble to buy dry argon. I wouldn't give up on this option just yet!
- http://canada.newark.com/excelitas-tech ... dp/79K2555
http://canada.newark.com/excelitas-tech ... dp/79K2558
http://www.thorlabs.com/thorproduct.cfm ... er=FDS1010
http://www.digikey.ca/product-detail/en ... -ND/481806
- Moses2015(MoSI).pdf
- (503.5 KiB) Downloaded 415 times
