Neutron Scintillation Detector: start up work
Post by Dennis P Brown » Wed May 17, 2017 11:09 am
The neutron sensitive plastic I have (a rather large piece) has a bit of crazing on its surfaces. I have been using plastic polish and a buffing wheel to remove the more shallow "cracks" but the deeper stuff will require that I create shallow depressions in my detector surface - no way I will regrind and polish this block flat; just not interested in that level of effort. As such, does anyone know what is the best contact gel or silicone sealant to use as an interface for the plastic and photo-multiplier and where to get said material? I require such a material to both provide a good optical transmission interface between the plastic and detector, as well as fill in any depressions.
Also, since I have a large hole saw (same diameter as my photo-multiplier tube face) I would like to stack a few cylinders of cut plastic together to increase the collection volume and create a good optically clear interface between the stacked cylinders.
The plastic block I have is BC-412 - its peak emission spectra occurs in the 420-460 nm; so, rather blue when it is stimulated by neutrons.
richnormand
Real name: rich normand
Re: Neutron Scintillation Detector: start up work
Post by richnormand » Thu May 18, 2017 12:15 am
Here is an old post:
viewtopic.php?f=13&t=6255&hilit=+coupling+gel
If you follow the links in there is another set of post about coupling gel.
The "real" coupling gel is quite thick and expensive. I had a scintillation block that was quite crazed and I had to machine most of the surfaces out but not all. Used NOVUS platic polisher kit.
Someone here pointed out thick oil for RC differential gears used in carts. It's available in many hobby shops. It worked quite well and was drawn in the surface cracks after a few days.
I did not have any issues with the oil seeping out after several years either. Just be careful on how much you use.
After all these years the interface between block is near perfect.
Hope that helps.
Bruce Meagher
Real name: Bruce Meagher
Post by Bruce Meagher » Thu May 18, 2017 10:23 am
Dennis,
The following link has some info about different optical coupling greases http://www.logwell.com/tech/servtips/op ... rease.html
I saw this on eBay http://www.ebay.com/itm/262765111357?, but I'm not too sure if it's really a grease (vs oil). Ideally you want to match the refractive index (RI) of the optical coupling grease to the RI of the PMT window material, or the RI of the detector material, to minimize light losses.
Are you thinking of using pulse shape discrimination to differentiate the neutron interactions from gamma interactions in the BC-412?
Bruce
Post by Dennis P Brown » Fri May 19, 2017 12:38 pm
Very nice posts; I'll order some of the oil - looks promising since it could help reduce the effects of the crazing. Thank you both for the help!
Roberto Ferrari
Real name: Roberto Ferrari
Post by Roberto Ferrari » Fri May 19, 2017 2:13 pm
Rich, Bruce
I remember Richard stated that plastic scintillators weren´t adequate for fusor work. I supposed was related to lower sensitivity of plastic scintillators.
Am I wrong?
Roberto
Roberto Ferrari
Post by Roberto Ferrari » Fri May 19, 2017 2:16 pm
Here is the quote:
Re: FAQ - Choosing a Gamma Spec Scintillator detector
Unread postby Richard Hull » Thu Mar 24, 2016 11:44 am
Plastic scintillaors can never be used for Gamma Spec work. Absolutely unacceptable.
Post by Dennis P Brown » Fri May 19, 2017 2:45 pm
This plastic is for neutron detection and BC-412 plastic is sensitive to neutrons; it is doped to fluorescence efficiently upon impact by fast neutrons. The company specifically states in the technical paper that it is insensitive to gamma's (5 MeV >.) Relative spectral resolution, Richard is correct. Of course, insensitivity to gamma's is a desirable feature for a neutron detector.
Roberto Ferrari
Post by Roberto Ferrari » Fri May 19, 2017 4:20 pm
Thanks Dennis!
Roberto
Post by Richard Hull » Fri May 19, 2017 10:04 pm
Bottom line......Use the 412 and put an extremely hot source of gammas near it. A Cs137 10 uCi source is good...(easily purchased). You should see nothing. If you see something it is no good. Still, A gamma detection might be able to be windowed out, electronically, provided the neutron signal is much more intense. What is the efficiency of 412 for neutron detection???? Will it need a moderator or is it detecting fast neuts directly???
The BC720 I struggled with between 1998 and 2002 detected only fast neutrons and was about .5% to 1% efficient. You need a torrent of neutrons to get a few detects/ second.
I spent over $600 with Bicron on neutron plastic detectors in the early days and was grossly disappointed. Any plastic other than the BC720 in a detection scenario would be suspect in amateur hands due to a very low efficiency and proper windowing warranted by the user having an instense gamma and neutron source at hand to convince a critcal review of their neutron detection results via proper level detect isolation.
I know ...........Been there and barely done that successfully for only $600.00 spent.
Post by Dennis P Brown » Mon May 22, 2017 10:39 am
Thanks Richard!
Since my fusor puts out at least 3*10^4 neutrons/sec and I suspect a good bit higher I would hope that is enough; so, while hardly "hot" I again hope that my $120 worth of parts (plastic/photo-multiplier/interface board) and with my ST-360 counter I could then obtain enough counts so that I am above any noise floor. If not ...well, not a big loss but I am hoping this plastic works because noise issues from my Russian tube is a huge problem now. (My other scintillation detector system is only for x-rays/gamma but does work well - even picks up Beta (rather shocked by that ability.) But that system is solely used as a radiation safety detector system.)
