Want Some Big He-3 Reuter Stokes Proportional Tubes?
A mere $6K each........He-3 shortage and all.......
supply and demand in action .
Saw a similar one earlier.....$5500 bid did not meet reserve.
http://cgi.ebay.com/Neutron-Detectors-V ... 27b0ff6659
Jerry
Jerry
- Carl Willis
- Real name: Carl Willis
Re: Want Some Big He-3 Reuter Stokes Proportional Tubes?
They asked me to come up to Espanola and test these units with a neutron source and prepare a little report a few months back. So I can vouch for their proper operation. I also know that the asking price is based on several offers they have already received for the tubes alone.
Take-home message: hang onto your He-3 tubes. They are a valuable investment.
So, the huge, (for a hamfest), $200.00 price I paid for the 24" brand new P4 GE/Reuter and Stokes at the Vienna, VA Hamfest a few weeks back was a good deal.......
Like Carl says, hang on to yer' 3He tubes for dear life.
Looks like a good investment if you have one.
http://www.newscientist.com/article/dn1 ... e-dry.html
Dustin
Dustin
I love the part of the article where Pacfic Northwest labs is working on new neutron detector tubes that use boron tri-fluoride or even boron lined tubes. What is old is now new again. Wonder of wonders. I new they would find a clever work-around....Such sheer genius. Why didn't someone think of these novel new tubes 60 or 70 years ago?
Another apparently sterling example of public tax dollars hard at work, eh?
But I rather suspect they mean to revisit the older techniques and see if they can be improved. But of course, we all knew that ....
- Carl Willis
A much better BF3 tube could be made just by filling to pressures above 1 Atm. Almost everything commercially available now has 1 Atm or less, in order to comply with DOT toxic-gas HAZMAT restrictions. He-3 tubes routinely have several Atm or more. BF3 tubes even have a few nuclear advantages, including a better neutron-to-gamma pulse height ratio. It's a shame to see He-3 become so precious, but there's nothing really magic about it.
I don't think it's just a DOT restriction. I was also wondering why manufacturers didn't pressurize BF3 tubes higher than 1 atm, until I stumbled across this nugget in Glenn Knoll (3rd ed):
"Because the performance of BF3 as a proportional gas is poor when operated at higher pressures, its absolute pressure in typical tubes is limited to about 0.5 - 1.0 atm."
I'd hazard a guess that BF3 is somewhat electronegative, and starts acting to self-quench at higher pressures, like sulfur hex would.
There are probably many ways to skin this cat. Generally, in technology, where there is a will, there is a way........Especially if there is a payday at the end of the process.
The neutron measurement situation is not dire; it is just thrown into some disarray as the applecart of normal operational flow has been upset. BF3s and B lined tubes will just make a comeback using tighter and more modern and clever electronics than that used during their heyday. BF3 tubes never really went away or saw the drop in use that boron lined tubes did. All had and still have applications based on flux levels where they are to be applied.
A lot of experimental, low flux operations saw immediate relief once the efficient, pressurized 3He tubes came into being, pulling older methods' results out of the experimental noise floor. Thus the rush to the 3He, especially for detecting small or shielded amounts of hiden or lost nuclear materials. This was magnified 100X after 9-11 while the production of 3He was stagnant or reduced.
In the short term, especially in the surplus sense, this current situation with 3He will have an effect on newbie and upgrading adepts among us. It is just amazing it all happened so fast.
- Carl Willis
As usual, Glenn Knoll is pretty much the last word on detectors. So maybe there's little hope for a better high-pressure BF3 after all. Good catch, Chris.
