You can find the start of this thread in :
viewtopic.php?f=6&t=2420#p11930
Spherical linac fusor - discussion - how to control ion trajectory
Re: Spherical linac fusor, construction and theory.
There is no way to respond to any of these. No way to continue individual threads. This post should be deleted.
There is no need to transfer files. It is not required. If transfered They should all be answerable individually as in the originals. This means they must be in the form of an original posting here with a new title conforming to the search rules. This forum is going to become a hell of a mess if we don't rigidly stick to this.
What little I have transfered I created as new posts with the old text. I brought over NO RESPONSES. I did not erase anything I transferred from the old forum.
Finally, you did not use the proper titling procedures that would help us search on this material. Check the rules posting and look at what is up already.
I will let your posting stay up a day or so and then it might be erased as it is data that is bunched and not individually extensible or answerable. If you have this much stuff to transfer, leave it where it is. Just post here in future anew for non-fusor stuff.
taking out tolerances
Darius,
you make some interesting comments.
If I understand you correctly, you support the idea that one can take out the effects of mechanical tolerances by electrical tuning of the grid. Do you have any ideas how we could do this in practice? The Einsel lens is one way but it makes construction hard.
Regards
Paul
Regards
Paul
Re: taking out tolerances
Paul,
I want to articulate further on this subject. But I have to revist some 345pgs in a book I have. I won't mention it because I would like to have a chance to make some persuasive arguments before I deal with the forum and it's celbrity....it detracts from curretn thought pardigms and I would care not to loose your attention if I put any real effort into your enquirey.
....but loosley yes, I do believe there is an appreciable effect to be garnered in fine dynamic application of ion trajectories. After all, as with everything there is a 'dance' going on there...and like minstrels we must enchant them into giving their gems of energy to us.
Darius
Paul Riley wrote:
> Darius,
> Regards
> Paul
Darius
Paul Riley wrote:
> Darius,
> Regards
> Paul
Construction Material
Adam is correct, I suspect you will have serious out-gasing problems with epoxy fibre glass renforced board. Most of the solvents used for the epoxy { Acetone, Isoproponal, Ethels, Etc. } are organic and are notorious at gasing for ages. I would doubt if you will ever reach a working vacuum and maintain with normal ( small ) pumps. Perhaps someone more experienced with Hi-Vac materials will comment.
by John Hendron.
by John Hendron.
Re: Construction Material
John,
Thick film hybrids use Al2O3 with gold screen print. The whole lot is sintered at > 600C. Would this be better than PCB material?
Paul
Paul
Yes! A much more stable choice, but with sintering it is better to bake for a long time to remove residuals. >600c for several hours is the norm for Zeolites used in a sorb pump.
