Ludlum Model 9
- Andrew Robinson
- Real name: Andrew Robinson
Ludlum Model 9
Well I finally decided to resurrect the old Ludlum Model 9 and give it its day in the sun. Like many of these hand helds, someone left the batteries in too long. I acquired this one after the fact so I cannot be held accountable or scoffed at haha. At any rate though, it only seemed fitting to give this little guy the full make over. So, without further ado, here is the process thus far...
- Andrew Robinson
Re: Ludlum Model 9
All cast parts now cleaned up. New paint and touch ups tomorrow in preparation for heading out for silkscreen.
- Andrew Robinson
Re: Ludlum Model 9
Here are the silk screen templates I created to reproduce the front panel. They are to scale.
Re: Ludlum Model 9
Completely over the top on this effort. I have never seen this done. I woulda' cleaned/replaced the contacts sanded the battery box and shot a little paint over the sanding work in the box and that would have been it. I have restored many, many counters of all types over the years, but never went to this length. Great job!
- Andrew Robinson
Re: Ludlum Model 9
Anything that's worth doing is worth over doing
Still waiting on humidity to drop to a more acceptable level for first coat of paint. Decided on a silver hammered look. Should be a great choice to contrast with all the black. I am a little sad about the tan though. I have always had a love hate relationship with Ludlum tan. Ultimately I decided not to try to replicate it. It just wouldn't come out right. The hammered silver will be really nice. More updates soon once humidity drops (Hate painting inside shop). Thanks for the praise Richard.
- Andrew Robinson
Re: Ludlum Model 9
So after two paintings... Yes... two separate. I screwed up the first try (at least by my standards) and had to re-sandblast EVERYTHING haha. Second attempt came out more to my liking. I finally decided against silkscreen. While its a really easy process and I have a shop that sends out parts for silkscreen sometimes twice a week, I just opted to hold off for now. I'm actually going to pass this little guy onto someone else who needs it. I have no use for this meter, but it was fun to breathe some new life into it for someone else to cherish for many years to come. Here are the final assembly pictures. The only thing I didn't do was silkscreen and replace the pin for the door. Both are very easy fixes though. I'm going to put it up on eBay if anyone here is interested. You should know about a few problems before bidding though:
1. I already said, I did not silkscreen it, however I will provide all the artwork I made to have it silkscreened.
2. The meter needle was broken initially. Since it was hanging by a thread I went ahead and snipped it so it looks much better. Still readable (see pictures)
3. The battery cover pin corroded away and was subsequently snipped flush. It needs to be pushed out and replaced, or you could throw a Velcro strap around the whole thing to hold together. Your choice.
That's it! Everything else is in PRISTINE condition. Brand new desiccant too!
Lots of pictures to follow:
- Andrew Robinson
Re: Ludlum Model 9
Last few images. I'll post the eBay link here soon too...
eBay link: http://www.ebay.com/itm/141422893885?ru ... 26_rdc%3D1
eBay item: 141422893885
Last thoughts. I have not officially tested this other than battery test. Sorry, don't have any sources right now. Selling for a great price as is. Sounds like its good to go though. Battery test is solid, and meter clicks away initially as the chamber stabilizes. The characteristic change in pitch feature is noticeable too. Up to you though. Everyone here should be smart enough to work on these things if you discover a problem I haven't noticed. Cheers
Last edited by Andrew Robinson on Mon Sep 29, 2014 7:35 am, edited 1 time in total.
- Andrew Robinson
Re: Ludlum Model 9
Last thing... promise. Here is the manual (little newer, but still for the Model 9)
Also, here are the original scans of the parts, the new template images.
Re: Ludlum Model 9
Wow! Will you ever get you money and time out of this effort? I figure 2 grand ought to cover it. See you in a few days.
- Andrew Robinson
Re: Ludlum Model 9
Haha, hear that everyone? Got the RH stamp of approval
See ya soon! Cant wait to dive through some NIM modules.
- John Taylor
Re: Ludlum Model 9
If Ludlum had seen that silver paint years ago, they would've trashed that disgusting tan. And that would have been fine by me!
GREAT WORK and it looks like a fair price too. I have a similar model 9 that I sometimes use for rock collecting, but it will never look that nice. Thanks for posting all the eye candy!
- Andrew Robinson
Re: Ludlum Model 9
Thanks for the nice comments. yeah I have always liked the hammered look. Very rugged, industrial look. Pain in the butt to get right though.
- Bob Reite
- Real name: Bob Reite
Re: Ludlum Model 9
Really a shame that the meter was damaged when you got it. It would be a perfect specimen otherwise.
- Andrew Robinson
Re: Ludlum Model 9
Off to bigger and better things. This little guy is off to an accelerator lab in Los Alamos. Fare thee well my dear little ion chamber.
