More Parts
Charles Vorbach
Real name: Charles Vorbach
More Parts
Post by Charles Vorbach »
Just got some KF parts for the chamber. I also got the varaic and hope to wire it up in the next few days.
Andrew Robinson
Real name: Andrew Robinson
Re: More Parts
Post by Andrew Robinson »
Looking good Charles!
Charles Vorbach
Re: More Parts
Still waiting on diodes for rectification, but I put the NST in an insulated box, hooked up the variac, and made a controller for my thermocouple gauge tube based on the Bell Jar's design (http://www.belljar.net/tcgauge.htm).
It uses an op-amp to amplify the thermocouple's voltage to 1 volt full scale and is a nice alternative to buying the controller. I don't have the tube yet, but once I get it I am going to test it/use it to test my vacuum pump. It's an interesting situation, but I think I'll be able to figure it out.
Charles Vorbach
Re: More Parts
Finally got the diodes and hooked up a rough rectification circuit. I am going have to think about how to make it look pretty. Anyway, I will be setting up the voltage divider and meters in the next few days.
Re: More Parts
I'm glad to see you used only the proper HV rated wire.
Bob Reite
Real name: Bob Reite
Re: More Parts
Post by Bob Reite »
!!! Oh that last comment was supposed to be in jest.
Andrew Robinson
Re: More Parts
"Transparency" read through the Rubbermaid bin ;)
Return to “Images du Jour”
