Over the past two years I have been collecting parts for my fusor. Due to other interests and work I have not really had time to build. However, I have decided to start up again. Here are the parts collected over the past years...
The first image is my diffusion pump. It came out of an Alcatel ASM-10 helium leak detector. It has an ISO 80 inlet flange and an NW 20 outlet flange. The pump should require a 6cfm vacuum pump and at least a pressure of 50 microns for it to start.
The next picture is my vacuum pump. Its a 2 stage, 4 cfm pump with an ultimate vacuum of 3 microns. I will take off the flare fittings then replace it with an NW 25 flange and hose.
ISO-80 to 2.75" conflat adapter and o-ring.
The main chamber consists of a conflat 6 way cross attached to a 3 way. The 3 way cross adds extra ports, allowing the gas to be injected further away from the pump and grid.
The bellows and gate valves will allow throttling of the chamber. The butterfly valve will just be used to isolate the chamber from the pumps.
The up to air valve and a Mastercool thermocouple gauge.
30kV feedthrough.
The gas system will contain of a CO2/Argon regulator with a 5 micron copper orifice.
Fusor Construction and Start
- Real name: Erik smith
Re: Fusor Construction and Start
Nice; now the issue is putting it all together and testing it for high vacuum! Really the fun part but also a major milestone for your goal of making a fusor.
I ran the fusor today in demo mode using a corkscrew grid and flyback power supply. The voltage is around -5kV and the current is around 1mA. As of now, I am waiting for the mineral oil to arrive for my 50kV XRT.
Superb demo system, Erik! I have placed your name in the Plasma Club.
Here is my 50kV XRT. I have yet to install my 100 half wave rectifier, or my 60kΩ 220M resistor.
Here a few pictures from 2 weeks ago. Since then a lot more parts came in. The only thing I still have to assemble is the drying stack for my PEM generator. I am still waiting for my neutron detector to arrive.
The chamber is almost done. all I have to is create the grid.
