Making My First Successful Film
ian_krase
Real name: Ian Krase
Post by ian_krase »
The glow discharge is actually pinker/paler than it looks here, and the parasitic glow around the periphery of the cathode shell is significantly dimmer than it looks in the picture. The cathode is copper sheet. Pressure is about 400 millitorr.
Yield after several hours was an oxide film that could be scratched off with metal tools but not with a fingernail or paper towel, despite the glass substrate being utterly filthy.
Andrew Seltzman
Real name: Andrew Seltzman
Re: Making My First Successful Film
Post by Andrew Seltzman »
Nice, what type of plasma/ion source is that?
Andrew Seltzman
www.rtftechnologies.org
ian_krase
Post by ian_krase »
It's a planar magnetron.
A small stack of neodymium ring magnets are placed around a top-hat-shaped steel core, which also has an O-ring groove and the two cooling water tubes (1/8 inch refrigeration tubing). A copper pipe cap (w/ thinned end and soldered on tapped ears) is slipped over and screwed down, compressing the O-ring. A cathode plate is then bolted to the top. Copper is currently used, but I intend to try silver since it's cheap.
Cooling water is supplied by a large 30ml syringe and a yogurt tub full of water; the low power of this system means that very little water is actually needed but it can't be allowed to go dry.
Gas is air, as you could probably tell. I intend to use argon, but don't have a cylinder or regulator yet.
ian_krase
Post by ian_krase »
I managed to hit a jackpot: Found a tested industry-grade pump (Pfeiffer Duo 2.5) at a low price on Ebay. I can get to 7 millitorr, and could likely get lower if my Pirani gauge wasn't leaking. Plus it has a gas ballast, has actual high-conductance KF input ports, and doesn't feel like it's going to burn up / wear out if run for an hour.
I also got a valve.
With this arrangement, I can actually see the green copper plasma. Sadly this is not photographable.
Congrat's! I too have scored a number of good two stage vacuum pumps on e-bay and I am glad you did! Deals come and go; so keep this in mind when looking for a high vac system and be patient (turbo or DP. They do occur! Ion gauges are often cheap and some tubes come with fittings! Never buy unless they provide a money back return policy - if not, don't waste your money. Deals will appear again.)
I assume you cleaned and then added new oil to the pump? If not, you should do so. Also assume the old oil and surfaces in the pump has been contaminated with a possible toxic or carcinogen so gloves are important. Waste oil needs to be disposed of in accordance with all local laws. (I use a local gas-station recycle tank (with their permission, of course; I assume you did replace the oil and followed good practices but I am just playing it safe.)
ian_krase
Post by ian_krase »
I drained the pump (foul-smelling, dark, almost greenish thick oil) and filled it, flushed it, and then filled it again. Results are what you see on the gauge.
6 millitorr is about the very best a really good mechanical pump can do!! What's the beef? A good pump down for a moderate foreline mechanical pump at the head is often 10 millitor! Move on, your pump is fabulous and I doubt your gauge is leaking.
ian_krase
Post by ian_krase »
I know my gauge is leaking because it responds to dust-off. It's an uncommon pirani and piezo combo, meant for loadlocks and other things that really really care about pressure mechanical force. The piezo sensor is joined with a mildly silly o-ring seal that has a slow leak.
Yeah, it's time for diffusion - or more likely, for inert gas backfilling to around 100 mtorr.
ian_krase
Post by ian_krase »
Today, I finally got my hands on enough KF16 clamps (hooray for living within walking distance of Duniway Stockroom!) to attach my chamber and my convectron at the same time.
Then I was a bit confused as to why I couldn't get below about 80 microns.
Turned out my spark plug feedthrough was leaking around the center pin. Conveniently, the entire top of my vacuum chamber is metal and insulated (via the glass walls) from the bottom. So I just blanked it off and moved the wire.
Result was successfully extinguishing the glow, and just before that, it was white rather than pink/violet (which the photo as usual doesn't capture very well)
I am going to come up with a better feedthrough.
Excellent. That is a nice setup you have constructed.
ian_krase
Post by ian_krase »
Casting a silver sputtering target. A silver bullion coin was bent in half, melted in a crucible, and poured into an open mold (made out of some kind of "alumina plaster" called Resbond 919). The mold was then heated and a little brazing flux added to re-melt and clean up the silver. Finished "button" should be about the size of a nickel, and will then be cold forged to proper thickness and clamped to the magnetron with aluminum or brass clips.
ian_krase
Post by ian_krase »
Today in "Ian messes around with sputtering while waiting to get guidance and setup for cleaning glass substrates", I tried sputtering silver onto a piece of paper (from a clothes price tag). It worked, to my surprise (since my other organic substrates failed miserably with goop).
I had to run it in short pulses to deal with the massive outgassing whenever the plasma hit the paper. After a while, I was able to quickly pump down to 20 microns (low enough to extinguish plasma if not careful!) but when the plasma was on, the pressure would gradually rise, reaching 60 microns pretty quickly. Keeping the pressure low but the plasma ready to restart (which requires around 26 microns) was tricky, not much like sputtering on glass or ceramic where once the initial outgassing is dealt with you can just set the leak valve and the isolation valve and run with it.
Electrical resistance is about 7 ohms over a distance of 7mm.
Bonus picture of my overall setup.
Not exactly a fusor post but congratulations on smelting (why?) and sputtering; yes, plastics and many organics can be coated via sputtering (it is a very low temp method. More like a super fast "diffusion" process than a vapor deposition method (which it obviously is not.)) So, any of this work going to be used for a fusor, later?
Post by Rich Feldman »
Ian:
Are you familiar with the four-point probe method to measure sheet resistance of thin layers? It eliminates the contact resistance and current-spreading-from-contact issue. One popular, practical configuration has the four probes equally spaced in a straight line, with the film extending well beyond the probes in two dimensions.
The math is conceptually simpler if your film is a strip at least 3 times longer than wide. With force-current connections (e.g. alligator clips) at the ends, and measure-voltage contacts 1 width apart near the middle, the V/I ratio directly gives you the film's sheet resistance in ohms per square.
When metals are deposited by evaporation in vacuo, one kind of real-time thickness monitor is based on the changing frequency of a bare quartz crystal oscillator. I bet you knew that already. Don't know if it's applicable to sputtering. A four-point film resistance measurement could certainly run in real time, and be subject to temperature sensitivity.
Thanks for sharing the metalwork story. Nice little kiln you got there, and pictures apparently free of color pollution from near-IR brightness.
What's your button thickness as cast, compared to that of the coin you started with?
Dennis:
Did Ian say he smelted anything? Smelting is a high-temperature process that chemically reduces ore to metal.
Pablo Llaguno
Real name: Pablo Llaguno
Post by Pablo Llaguno »
Very nice setup Ian, your vacuum looks awesome! Question: the mini convectron gauge you bought, what fitting does it have, KF? Also, are you using a NST? Your vacuum chamber in the pic above looks black, that happened to mine and it was very difficult to remove.
ian_krase
Post by ian_krase »
I am aware of the four-point method, but I don't think I have the equipment to *do* it, and certainly not without messing around with a bunch of instrumentation. I mostly just wanted to get a comparison to my silver-on-glass and to the dead short of bulk metal plate.
I haven't *smelted* anything lately, but I'm going to be recovering some silver eventually, that might count. I did melt some silver to cast it into a sputtering target. Was in the form of silver bullion coin, and I needed a much smaller and thinner round sputtering target since my magnetron is itself pretty small. If I had my machine shop here, I would have just hammered it out and then cut a circle, but it was easier to melt it and cast it. The coin was nearly 1/8 inch thick, IIRC, and the sputtering target made from it via cuttlebone casting is more like 3/64, and slightly dished to fit the magnetron. I used a nickel as a model and then hammered it down slightly after casting.
That muffle furnace was probably not one of my smarter purchases. I'm considering selling it.
IDK if I will make anything fusorish with the sputtered films, but in a few days I will have the hardware needed to reverse the polarity on my OBIT-based power supply and then a demo fusor will probably quickly follow. Stay tuned, I guess.
I know about quartz crystal monitors, and have seen modules for them on the tiny SPI coaters (rotary-vane-backed, meant for preparing samples for electron microscope) but I don't have the feedthroughs or honestly the instrumentation expertise. Maybe later. Would be very cool to have if I could keep it from getting trashed by HV.
The convectron has a KF16. They commonly have that, KF25, or NPT. Swagelok VCR fittings are also common but I never even considered buying one. The plain old Mini-Convectron is much more common and less likely to leak than the Convectron ATM that I have.
I'm using an Oil Burner Ignition Transformer, which is very similar to a 12kV NST, but frequently cheaper and with a bit less current (25 mA rather than 30, IIRC)
The chamber looks black because the silver sputtering goes *everywhere*, not just on the substrate. This can be controlled using chimneys and baffles, potentially, but I don't have any. A closer look would show that the "black" is actually silver where it's thicker. Eventually it will get thick enough to short out a feedthrough over the insulator (this can be limited with baffles on the feedthrough). To remove it, I use potassium nitrate mixed with vinegar (poor man's nitric acid) and a swab to scrub the silver off of the glass and ceramic portions. This is a *mostly* mechanical process, with the acid only dissolving a little bit of silver sufficient to loosen the rest. Then I wash the chamber first in soapy water, then with acetone, then with alcohol. Your coating won't be silver if you didn't have any in the chamber but this method will likely be effective against a variety of metallic and metal-oxide contaminants. (Many will be removed by muriatic, aka hydrochloric acid which is in hardware stores). If it's sooty or organic, you might be in for a harder time and/or scarier oxidizing treatments. IDK.
ian_krase
Post by ian_krase »
Well, my labors have borne fruit. Today, I RCA cleaned the substrate and, without touching it with either gloved or bare hands, transferred it to the sputtering chamber clamp.
The result was a film that was not pulled off with scotch tape, and which accumulated pinholes when brushed maybe 2-3 times slower than previously.
It wasn't perfect, as you can see a large swath *did* come away with the tape. However, I tried twice right down the middle and the bulk of the film persevered.
ian_krase
Post by ian_krase »
I managed to use sharpie marker as a resist for a lift-off process, though I think i contaminated my film... somehow. Actual pictures coming tomorrow... because I am tired.
Ian
True sputtering requires the atoms to have energy to overcome whatever bonds are prevalent on the surface de jour
so you need to acellerate the ions so thay have 100 eV or above so when they arrive at your substrate they can dislodge contaminants
(such as water vapour, grease or whatever) and combine with the ligands protruding from the surface to make a true chemical bond
any less than what i am saying makes films equivalent to evapouration ie they do not pass the 3M test (sellotape at right angles).
you will need to bias your substrate negative to the tune of 400 to 1000 volts to get this to happen with the scheme you are using.
so why 400 to 1000 volts when all you need is 100
mean free path, surface contaminents, physical reality, and a measure of good luck.
all for now have fun!!!!!
ian_krase
Post by ian_krase »
I've already passed the 3M Test several times. Sample preparation is an RCA SC-1 clean.
I'm not sure how I would bias my substrates with a well-defined voltage when they are made of insulating glass. And what would they be biased relative to, the target? Or would the bias be applied to a plate mounted behind a thin substrate? John Strong doesn't say anything about this.
In any case, I don't have the feedthroughs needed for that, and my substrate clamp (as you can see in the pictures) is by mechanical practicality connected to the cathode. Meanwhile the anode is actually above the substrate.
The last test (described, not pictured) was as follows:
- Take fresh microscope slide, cut in half
- RCA SC-1 clean (NH3 + H2O2 + H2O)
- Rinse and dry (DI water)
- Draw pattern (cross) with Sharpie marker
- Mount, close chamber, pump down to 35 micron air
- Commence sputter, regulate pressure (air) between 20 and 50 microns
- Stop sputter when the entire sample is sufficiently opaque that a lamp cannot be seen through it (harder than it sounds)
- Stick Scotch tape to the sample, and peel off at 90 degree angle (removes silver from over the sharpie marker, but not the clean area).
- Wash with ethyl alchohol
Result: A silver mirror on glass with a cross-shaped clear unsilvered area
The plate is biased; at those voltages and pressures the gas conducts and the ionized atoms "knock" off metal atoms that then move to and adhere to the glass. Your picture shows a rather badly "burned" film. It might just be the photo but if not, the issue of contamination looks to be a problem in your system. I don't bias my substrates but do use a DC voltage in the high hundreds (400 - 850 volts.) I've used higher voltage systems with magnetrons.
Also, your pressure is a bit on the low end. By the way, do you use air or argon? Air with oxygen can causes issues with your films.
Using an RCA cleaning process is over-kill for most sputtering systems (that is generally used only for semi-conductor systems and require ultra clean glassware ...); in any sputtering system the ionized gas will clean the substrate as long as you have first used alcohol to clean it of any minor contamination. For grossly contaminated glass surfaces using detergent and water, and then following this up by alcohol is ok.
I sputter films all the time and routinely make ultra-high quality films and I don't even bother to clean the substrates since standard slides are more than clean enough (you are using gloves to handle them?)
ian_krase
Post by ian_krase »
I'm using air, as I don't have access to argon yet. DC voltage you mean is just the magnetron sputtering voltage? Mine is probably something similar, I don't have any instrumentation. The power supply is a rectified OBIT.
I know the pressure is a bit low. One frustrating problem is that either higher pressures or the low pressures I mentioned work due to Paschen's Law, but intermediate pressures cause the plasma to leave the magnetron. But its my impression that sputtering works at a wide range of pressures and lowering the pressure makes it more radiant.
It is 110% the light in that last picture. My workspace is poorly lit and the surroundings are not of uniform color. Most of my films are pretty much white silver.
The last film i did, with the cross, is burned/contaminated and actually is the way that picture looks.
Yes, all my sputtering is done with DC.
Any good sputtered film will be a highly specular - that is, perfect mirror reflector on a piece of glass.
I sputter onto very thin plastic films (as thin as 20 microns) all the time with no trouble since sputtering and the plasma offer no significant heat load; that is not always the case for the grounding plate, however; and that can cause issues. So for thin plastic films I mount them above the ground plate using a plastic support.
Argon is popular for home based Tig welding and inexpensive (comparatively) gas systems are available in many locations. Argon is vastly superior for sputtering and allows for very high quality films to be deposited.
Scientific American has an excellent article on Sputtering in its Amateur Scientist back in the Oct 1967 issue.
Dennis sure is fast!
I was about to ask who else remembered that old Amateur Scientist column, from the era that I grew up with. Really cool projects, including plenty that could kill you if followed carelessly. And things that today would scare people for miles. Amateur glassblowers could work their way up to DIY mercury-vapor diffusion pumps. Bookstores were allowed to sell the magazine to just anybody!
Ian, do you live in the San Francisco Bay area?
My day job is across the street from a company called Meivac, where they manufacture industrial sputtering systems & similar vacuum gear. I got a tour & some free stuff once, years ago, when I was mentoring some science fair kids and first joined this forum. Could find my old contact info if you're interested.
ian_krase
Post by ian_krase »
Oh, cool!
I live in the south bay area bordering on Silicon Valley, and work at a company that makes MEMS devices (though I am not at all involved in microfabrication processes). I'd love to have that info.
I've been scheming to set up argon, but it costs money and I've not yet decided to spend it especially as the results on silver are so good without it.
My sputtered films are quite specular, though the exact specularity isn't totally uniform -- there's a very faint haze in the center. Of course, it's easy to sputter long enough that spalling starts and then it's not so nice.
Return to “Images du Jour”
