MATER-1
Posted: Tue May 01, 2018 1:50 am
The following post depicts MATER-1: Massive Amateur Test Electrostatic Reactor Version 1.
This fusor was constructed over the past year by myself, Timothy Koeth, Jay Howson, and Jimbo Krutzler.
All of the equipment seen in this project was acquired through surplus sources.
System:
Vacuum: The vacuum system consists of a 2-foot diameter, spherical chamber with 26 ports. The chamber is roughed with two mechanical pumps; one large Edwards mechanical pump to bring the chamber down to 4 mTorr, and a second which backs a 50 l/s turbo pump. The base pressure of the chamber is 5e-7 Torr.
High Voltage: The high voltage system consists of a Glassman -80kV 38 mA supply. We also have a -150 kV 2 mA supply which will be used, but does not provide as much current for a high neutron output.
Neutron Detection: Our neutron detection consists of four 3He detectors: A Texlium "Special" 22" detector, a Reuter Stokes RS-P4-0820-103 22" detector, an LND 2520 8" detector and an 8" Reuter Stokes probe. As of right now we have the two larger detectors setup with full NIM instrumentation but are working through issues with electrical noise. In addition, we are using activation and a sensitive HPGe to confirm our neutron production.
Gas supply: The gas system consists of a deuterium lecture bottle as well as a needle/shut off valve. This provides sufficient gas control to maintain the same pressure for hours.
Shielding: Our shielding consists of a >1" Leaded glass panel
Our hope is to use this machine as a platform to run others' experiments and test ideas. Please feel free to suggest different experiments.
First Run:
Our first neutron producing run was at 4 mTorr of deuterium and 55kV /7 mA on the high voltage power supply. This was suffecient to activate indium after a 10 minute exposure (note second to last picture). Also note the HPGe Spectrum in the last image.
We have much much more to come, so please stay tuned. We hope to calibrate our detectors and give a total isotropic emission rate.
System:
First Run:
