Archived - Typical welded fusor shell
daniele
Post by daniele »
Hi all,
my fusor chamber was finally welded.
Since I was not so good in welding, I'll have to grind the inside a bit. Welding hemispheres to flanges was easier to do.
Tubing to hemispheres was harder, so grinding a bit to remove some material in surplus, is needed.
Anyway I'm happy of results achieved, I'm not an expert welder, but for the first assembly I make, It's not all that bad :)
ciao all
Daniel
Return to “Images du Jour”
