Archived - My First Operational Fusor !!
guest
Post by guest »
Here are a couple of shots of my first working fusor. The first is of the overall setup and the second of the poisser.
The chamber is a converted propane tank and the viewport is homemade off my lathe.
In these shots, its being powered off an NST at about 25% power. The NST is a 15KV at 30ma. which means its total output is only a mere 3-5kv. My big Universal Voltronics 25KV / 60ma supply had a resistor failure and is currently being repaired. Once done, I will post a couple more pics.
Garage Scientist (Unlicensed)
Return to “Images du Jour”
