Attached is a schematic and some instructions for constructing a HVAC generator using a modified flyback transformer. The flyback used should be unpotted so that the core halves can be taken apart to measure their cross sectional area and to remove any gapping material that is between them.
If you choose to take on this project, you are on your own. I accept no responsibility for fires, shocks, explosions, and/or hurt feelings. The circuit is advanced - if this is your first electronic construction project, pass on by or find somebody with experience (and equipment) to help you out. The generator is unprotected - if you short or draw an arc from the output, you may blow it up - beware.
HVAC Generator using Modified Flyback Transformer
- HV_Supply.pdf
- (17.88 KiB) Downloaded 245 times
