Andrew Robinson FOR SALE (02/02/17)
Use this forum to offer / scavenge for fusor parts
Andrew Robinson
Real name: Andrew Robinson
Post by Andrew Robinson » Thu Feb 02, 2017 11:29 pm
UPDATED LIST (Electrical and Vacuum)
CONTROL PANEL - $500
Built this a few years ago because I had a variac just sitting on the workbench that I kept using unsafely (in my opinion) by just wiring right on the bench completely exposed. I decided to put it in a box, but then decided to add a few switches... Then decided to add meter... You see where this is going. It went downhill quickly and developed into this fun little side project. This would be a GREAT Tesla coil control panel. Its portable and works with both 15A and 20A circuits. All the wiring and internals are setup for 20A, however I currently have a 15A plug on the end. Everything is very sturdy, high quality materials and workmanship. A solid state relay inside switches power on and off. The variac ranges from 0 - 140V. The only thing you should know about this panel is the meter. The voltage/current meter I used, gets its power from the source it is measuring. As a result, the meter only works above 60VAC I believe. You don't have to use this for Tesla coils. You can use this control panel for anything really. It can be a lighting controller or a motor controller. Really anything you need to control the AC line to. Power your NSTs. You decide. I put a LOT of time into this and sank a considerable amount of money into the components and as a result I would like to at least make some of that back. Asking $750, but I am open to reasonable offers.
Last edited by Andrew Robinson on Thu Feb 02, 2017 11:37 pm, edited 2 times in total.
Andrew Robinson
Re: Andrew Robinson FOR SALE (02/02/17)
Post by Andrew Robinson » Thu Feb 02, 2017 11:35 pm
HEAT SHIELD - $20
This was my first revision of the heat shield you can see here viewtopic.php?f=18&t=10191&hilit=+rapid. I have no use for it anymore. Perhaps someone out there can find a similar use for this.
KF25 CLAMPS - $10
I bought these a long time ago and am no longer using them. 4 of them are brand new. 1 came with an old pump I purchased. These are KF25 standard aluminum clamps and have actually never been used expect for maybe an initially assembly test (excluding the old one of course).
Andrew Robinson
Post by Andrew Robinson » Thu Feb 02, 2017 11:46 pm
VACUUM VALVES - $75 - $200
Up for sale are some pneumatic and manual 2-1/8" bellows valves. The pneumatic valve is slightly used but in great condition except for some scuffs. The knife edges look perfect, but I have not installed this particular valve in a system so sold as is. The manual valve is brand new. The pneumatic used valve is $75. The brand new valve I will let go for $200.
