Vacuum Throttle Valve
Use this forum to offer / scavenge for fusor parts
Hunter Long
Post by Hunter Long » Fri Jan 12, 2018 2:51 am
Hey guys,
I'm selling a vacuum throttle valve and controller if anyone is interested: https://www.ebay.com/itm/112729532424?s ... 1558.l2649
Also, I have a VAT pneumatically actuated gate valve that I was going to list on Ebay, but haven't yet and a few other parts that I removed from a reactive ion etching system. I believe there is a thermocouple vacuum gauge and a bellows right angle valve too.
Thanks!
-Hunter
Tom McCarthy
Real name: Tom McCarthy
Re: Vacuum Throttle Valve
Post by Tom McCarthy » Fri Jan 12, 2018 4:05 pm
Is that a 6-inch conflat fitting?
Post by John Futter » Fri Jan 12, 2018 5:55 pm
Hunter Long
you need to change your login name to your real name
No handles only proper real names as per the rules for Fusor.net
Post by Jerry Biehler » Fri Jan 12, 2018 10:50 pm
That is ISO-100
Hunter Long
Post by Hunter Long » Sat Jan 13, 2018 2:03 am
I'm not sure how to measure conflat fittings, but the green throttle flap that moves is 3.75 inches in diameter (this is also the id of the valve).
Thanks, I just changed my login to my real name.
Post by ian_krase » Sat Jan 13, 2018 3:11 am
Conflat is normally measured by the OD of the flange in inches.
Post by Jerry Biehler » Sat Jan 13, 2018 10:25 am
Like I said, it is a ISO-100 flange.
Tom McCarthy
Post by Tom McCarthy » Sat Jan 13, 2018 12:23 pm
Thanks Jerry, I bid before figuring that out. Mistake purchase made.
Post by Jerry Biehler » Sun Jan 14, 2018 6:38 am
I should be easy to make an adapter. You can use rubber seals to mate to iso fittings from conflat.
Hunter Long
Post by Hunter Long » Mon Jan 15, 2018 12:58 pm
Sorry about the confusion, I didn't realize there were multiple vacuum flange types (apart from size differences). I've refunded the order.
The parts I have can be seen on the Google album linked below. In order of appearance they are:
1. Vacuum throttle valve and controller
2. VAT vacuum pneumatically actuated gate valve
3. 4" ID section with 1.6" ID and 2" ID branch offs and two 4" ID gaskets
4. Right angle bellows valve
5. T-section with DST-06M thermo-couple gauge
6. Two 2" ID O-rings and clamps
As of now all of these are still available, so if you want anything make me an offer. For some parts I measured OD and others I measured ID. However, for all of these parts there are only 3 different sizes (~5" OD and 4" ID, ~3" OD and 2" ID, and one with ~2" OD and 1.6" ID).
Pictures: https://photos.app.goo.gl/IpNq6qeN2gBRrlf42
Video of gate valve: https://www.youtube.com/watch?v=xz8AZdV-ZDs
