My name is Sergey, I'm a software engineer living in Moscow, Russia.
I'm interested in electrical and mechanical engineering, chemistry, astronomy and most branches of applied and theoretical physics.
Mostly I just like to craft things as a hobby.
I was led here in hope to introduce myself to high voltage designs and safety.
The idea to try and make myself a fuser also sounds tempting. )
Thanks for all your work!
Hello
- Real name: Sergey Filipkov
- Andrew Robinson
- Real name: Andrew Robinson
Re: Hello
Welcome Sergey, and best of luck to you. If you decide to go down the fusor path, be sure to read the FAQs. You might also check out 4hv.org and the tesla coil mailing list at pupman.com for other dedicated HV help.
Regards,
Andrew
Regards,
Andrew
