Hello from Michigan
- Real name: Thomas Suiter
Hello from Michigan
Hello from a random tinkerer from Michigan. I came across this site after buying a turbo vac at an auction without much though as to what I'd use it for. I've found what I want to use it for, the challenge of being able to create fusion is just the type of thing that peaks my tinkerers interest.
Re: Hello from Michigan
A good turbo is an excellent first component (for the vacuum system) but only a minor one. However, the nice thing with such a high vacuum pump like a turbo is they can be a bases for many high vacuum experiments. If you are serious about real fusion - then you will have to obtain a proper power supply (see the FAQ's); then deuterium gas and finally, a neutron detector. Best of luck.
Last edited by Dennis P Brown on Wed May 30, 2018 6:01 am, edited 1 time in total.
I tend to acquire bits and pieces randomly over time every week or so I troll through the local universities' disposition dept to find random nuggets of spent gold. First I have a lot of reading to do, and probably need to finish some other garage challenges first to make sure the wife doesn't get too grumpy
- Real name: Dennis W Winslow
Whereabouts in Michigan?
Have you found any like minded folk near us? Any local groups/clubs?
