A Quick Question
Duncan Wilkie
Real name: Duncan Wilkie
A Quick Question
Post by Duncan Wilkie » Mon Jan 08, 2018 3:15 am
Is Loctite 290 (or similar) acceptable on NPT at foreline pressures?
Re: A Quick Question
Post by ian_krase » Mon Jan 08, 2018 9:05 am
Definitely.
Alternatively you can use Torr Seal (aka Hysol 1C) which is good to at least 10E-5.
Post by Jerry Biehler » Mon Jan 08, 2018 9:37 am
Teflon tape usually works at foreline pressures.
