Materials List
David Conway
Real name: David Conway
Materials List
Post by David Conway » Sat Jun 16, 2018 11:32 pm
Attached is the start of my materials list with price estimates and ebay links / etc. Feedback is greatly appreciated.
Thanks.
fusorpartsdc.xlsx
(26.69 KiB) Downloaded 58 times
Niels Geerits
Real name: Niels Geerits
Re: Materials List
Post by Niels Geerits » Sun Jun 17, 2018 3:16 pm
Hey David,
My Fusor is not complete but I noticed a few things in your list. You can do cheaper on your high vacuum pump. I got an old turbo for 150$ and restored it + built the driver for it for about 100$. For the pressure just get an MKS901P, you can get them for around 50$ and they have built in read out electronics which communicate with your computer via RS232 serial. And if you are going to use serial comm with a pc you might as well use a webcam for viewing 20-30$ and you got a decent webcam. High Voltage 30kV @ 20mA is going to be a bit more than 200$ AFAIK, unless you are going for one of those precipitator supplies. Also you could save on vacuum stuff if you opt for KF50 6 way cross (its a bit smaller) instead of CF 5 way cross.
