Anyone recognize what type of flange this is?
Geoffrey Thomas
Real name: Geoffrey Thomas
Post by Geoffrey Thomas » Mon Jun 25, 2018 12:53 am
I bought a bunch of these at a flea market for $3 total. 50mm outer diameter, ~42 mm o ring diameter. I don't think it's for vacuum systems (more likely has positive pressure applications), but thought I'd double check.
Thanks,
GT
When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it. -Theodore Roosevelt
Re: Anyone recognize what type of flange this is?
Post by Rich Feldman » Mon Jun 25, 2018 1:44 am
See if they match the standard dimensions for "Sanitary" flange fittings. For example, in the drawings here:
https://www.buyfittingsonline.com/sizin ... ences.aspx
You might use sanitary fittings in a dairy or a soup factory. As with high vacuum parts, you want the inside walls to be smooth and easy to clean. When the catalog has elbows, tees, and crosses without flanges, they are for welded joints just as with vacuum plumbing.
https://hollandaptblog.com/2013/09/27/w ... -sanitary/
I work on electronic products that use sanitary fittings for aqueous coolant. The mech. engineers were intrigued by the similarity of some KF fittings I brought in, which support the O-ring seals against external pressure.
Geoffrey Thomas
Post by Geoffrey Thomas » Mon Jun 25, 2018 2:06 am
Thanks Rich.
Yep. That looks to be what they are. kind of surprised honestly since most of the stuff is marked "316l" and is wrapped in the same heat tape all of my CF gear is covered in, with the high temp white nylon braid covering the nichrome.
At least I got some good bakeout coils for the $3 I suppose...
Thanks,
GT
Lukas Springer
Real name: Lukas Springer
Post by Lukas Springer » Mon Jun 25, 2018 7:26 am
I'm not 100% sure, but compare the dimensions of "tri-clamp" with your flange, that might be it.
Post by ian_krase » Mon Jun 25, 2018 7:33 am
Yeah, that definitely looks like a sanitary ("milk pipe") flange to me.
I have seen them used in vacuum work in rare situations, mostly in things like the separation to open up foreline traps for replacing the media.
Post by Rich Feldman » Mon Jun 25, 2018 4:34 pm
Thanks, Lukas.
I hadn't previously heard the name tri-clamp for what appears to be the identical standard.
Another popular name seems to be Tri Clover, as used for example by this brewery supplies company: https://www.brewershardware.com/Sanitary-Fittings/
The clamps all seem to have one hinge. Maybe the tri names come from an original brand, kind of like the Schrader valve.
