Chamber contamination by vacuum grease
Yang Minju
Real name: Yang Minju
Re: Chamber contamination by vacuum grease
Post by Yang Minju » Thu Aug 30, 2018 8:39 am
I found the same cheaper ball valve on eBay!
https://www.ebay.com/itm/Ball-Valve-Vac ... Sw44BYLVKy
The seller says the working range is 5*10-2 pa(maybe around 3 micron?). I plan to use this as a valve between the diff pump and the foreline. I was originally going to find a better used valve, but I couldn't find one that would satisfy me...I think this valve can withstand the pressure between the diff pump and the foreline, and solving the problem easily by attaching a KF T to the rotary pump, then attaching a vacuum ball valve to the side, and a cheap ventilation valve to the top.
Thanks!
Post by Dennis P Brown » Thu Aug 30, 2018 10:16 am
Looks good and should work fine.
Yang Minju
Post by Yang Minju » Fri Aug 31, 2018 7:02 am
I bought a valve! The only thing left is waiting...
