Negative Polarity Power Source?
- Real name: Taylor Shead
Hello
As a few of you may know, I am teaming up with Ben Barnett do build a demo fusor as a research project for the university we attend (UTA). He is an EE student and I am an ME student.
We have access to a couple of power sources:
#1:
#2:
(I thought I had a picture of the front but apparently not)
I know we need the positive side to be grounded. I read a topic here that concluded that you can't just ground the positive. The supply needs an internal positive ground. Is this correct for a demo fusor?
Also it look like our option #1 can be reversed polarity but doesn't meet the amperage requirements.
Our option #2 almost meets the requirements for a fusion fusor but its polarity can't be reversed.
We talked about modifying #1 but I'm not sure our advisor will let us.
Can we make use of one of these for a demo power supply?
Taylor
#1:
#2:
Taylor
Re: Negative Polarity Power Source?
Regarding altering option #1. Usually all single polarity supplies like this are internally grounded to the case and power line ground in many places within the circuitry. This reduces required insulation internally.
Selectable polarity power supply units are far more highly insulated and place their grounding selector on a larger printed circuit board with pins, well isolated from each other on this "polarity selector switch board"
The polarity selectable supply might barely make a demo supply provided their is no current limiting. If their is limiting at 2.5 ma, then this will not work at all.
You might be back to a neon transformer homemade supply as a demo power solution.
For a demo fusor any power supply that allows the device to create a visible plasma meets your goal. Even a positive supply is absolutely fine for a demo device. Also, any low current supply is acceptable if it creates a visible plasma (like a NST.)
A demo fusor can be any level - even include deuterium gas for proper color but this device is only created to make an observable plasma.
Obviously, if one ever hopes to do real fusion in a fusor, a proper power supply (polarity, current and voltage) would then be needed and is a better approach for the demo since it will provide real experience handling both the voltage, current and issues of creating a stable plasma (assuming one is operating in the correct vacuum range.)
The power supply you show in the image is perfectly acceptable for a demo system. But that isn't a NST and that supply is dangerous; as such, careful precautions should be taken.
So if I used a power source with positive supply would I still wire the positive to the chamber and negative to the grid?
This is correct as I understand it but I want to make sure. We will likely stick with the bigger power source as it is cost effective. As for dangerous, we will be working in a room full of stuff that could kill us haha.
Fusion MAY be later (Summer 2019) but we are focused on the demo aspect currently.
Ideally, the purpose of a demo fusor is to create a learning tool that is a look-alike and work-alike for a fusor. Only a negative hot, positive grounded supply will serve here.
- Real name: Bern Bareis
-30kV, 20mA supply Spellman DXM30N600X4215 for $500: viewtopic.php?f=20&t=12493
- Rich Feldman
- Real name: Rich Feldman
Hey Bern, it's good to see you helping out at fusor.net.
Done any work lately with your own fusor?
So the negative hot is an absolute must? This will be difficult for us because we are on a time schedule. Most people aren't.Richard Hull wrote: ↑Tue Nov 20, 2018 2:14 am reate a learning tool that is a look-alike and work-alike for a fusor. Only a negative hot, positive grounded supply will serve here.
Bern Bareis wrote: ↑Tue Nov 20, 2018 1:51 pm -30kV, 20mA supply Spellman DXM30N600X4215 for $500: viewtopic.php?f=20&t=12493
I'm pulling my hair out right now because I just saw this and it sold two days ago. I would have picked it up too. Oh well.
If you really need fusor related stuff, a daily visit to the trading post is recommended.
That fabulous supply has been languishing, un-sold in the trading post since October 27th.
I couldn’t have purchased it until this week but now that money is gone. Our budget for the demo does not include a power supply. All I need to know right now is if there is ANY way we can use a positive supply.
for a demo fusor you can use a positive supply just as some use an AC supply ie neon transformer with no diodes
As I posted (had hoped you might have read it), and Mr. Futter said as well, any polarity will work for a demo fusor. That said, if you have diodes, the definition of the cathode and anode are created by connecting the correct polarity to a given part of the fusor. The negative to the cathode; then by default, the positive is the anode. For a real fusor, of course, the anode is ground as well. In a demo, your choice to use diodes and then follow the design of a real fusor.
