Fusor grid material
- Real name: Anthony Marshall
Fusor grid material
I was curious if anyone here has ever used tungsten rods for tig welders as the material for building fusor grids.
- Bob Reite
- Real name: Bob Reite
Re: Fusor grid material
Yes! Doug Coulter makes his grids partially out of tungsten tig welding rods, with end caps out of graphite, which can stand very high temperatures as long as it's in a reducing atmosphere (which it will be if you are flowing D2) or good vacuum.
Wyley
its time to correct your login name and follow the board rules
1) The first rule of membership in these forums is: you must create your account using your real, full, first AND last names as the LogIn/UserID for your account. If your name is John Smith, your UserID (i.e. login handle) must be John Smith, or John_Smith. This is the name that will appear in the forum listings. “JSmith” or “JohnS” or “JS997” or “handles” like “MrFusion” or “ProtonBoy” are NOT permitted. New accounts that do not adhere to this simple rule will be summarily deleted without any further consideration. Any questions? OK, rolling right along…
2) New members are required to introduce themselves in the "Please Introduce Yourself" forum prior to posting elsewhere on the site.
