So far, I've managed to buy: a 9kV 30mA neon sign transformer, a vacuum pump with an ultimate pressure of 15 microns and the various wires/attachments needed. The vacuum chamber was generously donated to me by Ross Moffett. It should take about 2 weeks for me to finish, due to the shipping of the radiation detector I plan to buy.
A few questions:
In my search for a radiation detector, I've found two options: 2 CDV-750 (0-200 mR) pens with associated charger, or a CDV-715 Geiger Counter. I've read that the 715 is not a suitable counter for 'normal' uses as it counts in R/Hr (1-5) rather than mR/Hr however I figured that it should be okay since the main purpose of getting the counters is to reassure my parents that no radiation is coming out of the chamber. I wouldn't be running the fusor for long durations anyway, not that it might last more than 30 seconds, so even if mRs of gamma radiation or x-rays left the chamber it would not matter much. Which would be a more suitable option?
The last component I need to build before the demo fusor is functional is a full wave bridge rectifier, made of 4 9kV 30mA diodes (my neon sign transformer is 9kV at 30mA), a smoothing capacitor of 0.03 Farads or 30 milliFarads [1] for a Ripple voltage of 100mV and two bleeder resistors of 32 Ohms (Fast Bleed) [2] and one that has a higher resistance, maybe 500 Ohms for a slow bleed arranged with a ON-OFF-ON switch such that either one is connected in parallel to the capacitor at any given time. I plan to submerge the entire full wave bridge rectifier in vegetable oil placed within a glass/plastic jar before using a vacuum pump to remove the air within it to prevent arcing between the components. I also plan on using fabrics with silica gel to prevent contamination of the vacuum pump, although I'm not even sure if oil in the pump would cause issues.
Just as a final check (this is to reassure my parents that this is safe to do), the demo fusor produces: Alpha, Beta, Gamma and X-Ray radiation. Alpha and Beta radiation are not an issue as Alpha particles can be stopped by a few millimeters of air, and Beta particles by a few millimeters of Aluminium (oh which the plates that comprise my chamber are made of) [3]. Gamma and X-ray radiation are produced by the high voltages used in the demo fusor, but will not leak out as I'm operating under 15kV [4]. However, I'm unable to find calculations as of yet on how much gamma and X-ray radiation is produced by a demo fusor (it would be low at 9kV no doubt, but some math would help when I'm trying to convince people) so a lead/paraffin combo shield is in the works as well as the purchase of either a dosimeter or geiger counter.
Some pictures: http://imgur.com/yvCnkGU,xjZYP6i#0
The latex gloves serve to float the NST away from the floor, which previous experiences have told me that high voltage is able to arc to. A solder-less grid bound with aluminium wires has been made, but has not bee connected to the chamber yet. The hose is a washing machine hose.
__________
[1] This is based on: (http://www.electronics-tutorials.ws/diode/diode_6.html). I moved the variables around to get: C=(I/V x F)+V with the values 0.03A, 0.1V and 100Hz.
[2] (http://www.learningaboutelectronics.com ... arging.php) with values Vc=50, Vo=9000, t=5, C=0.03
[3] (http://hyperphysics.phy-astr.gsu.edu/hb ... adact.html) Found at the bottom of the page.
[4] I remember reading this somewhere in the FAQs, but am unable to recall where.
__________
Thanks for reading.
A half-year update on the demo fusor and some questions
- Real name: Julian Kang
Re: A half-year update on the demo fusor and some questions
No fusor produces Alpha or Beta radiation or Gamma radiation. Most demo fusors never produce x-rays which are capable of penetrating the chamber. Basically zero radiation of any type in most all demo fusors.
