Very quick question on flanges
constantinbushofsky
Real name: Constantin Bushofsky
Post by constantinbushofsky »
This might be a dumb question and I've looked around the forum and faqs but I may have missed this somewhere so please forgive me. Where can one source 8"od 6"id bored cf flanges? I know they're very common but I can't seem to find any used ones or otherwise not-rediculously-expensive (I've seen some sites selling them for upwards of $300 each for some reason). Again, apologies if this is a dumb question or if it's already been answered and if so, please direct me to the proper thread.
[edit] I found lots of flat blank flanges on eBay. How easy would it be to bore one to work for constructing a two-hemisphere chamber?
Last edited by constantinbushofsky on Fri Jan 15, 2016 12:41 am, edited 1 time in total.
dH - TdS = 0
Re: Very quick question on flanges
Post by Jerry Biehler »
You dont buy used ones because they are usually welded to something. If it is a blank then you might find something on ebay.
Real name: Dennis Brown
Post by Dennis P Brown »
To get stainless steel vacuum flanges of a specific size one must either pay the real price for new, or get lucky and happen to find what one needs on ebay; patience is the key if one is on a tight budget.
I have used aluminum plates, machined the required flange sizes, holes, threads and just used o-ring seals to get around welding - made both windows and high voltage feed thru's for a steel chamber in this manner. If one has access to such machines and can do that work it is a huge savings (I have never even used a ruler for the O-ring grove sizes/depths and they hold to 10^-6 torr. But experience helps.)
David Kunkle
Real name: David Kunkle
Post by David Kunkle »
Can you handle $139 instead of $300?
http://www.ldsvacuumshopper.com/6tubeod.html
Bought lots of stuff from these guys- they're good to work with too. They usually have the best prices on new stuff when I can't find it used on ebay.
Ernest Rutherford
prestonbarrows
Post by prestonbarrows »
That is a per flange price and a chamber needs two. So double those figures. When I bought my 8 inch flanges with 6 inch ID they were $95 each from Lesker. Considering inflation and the 17 year time lapse, the increase isn't all that bad. If you are serious about your fusor project, buy these new, if possible.
