I'm looking to add to my (currently) small shop, with the addition of a welder. If I was (along with other things) going to attempt an amateur fusion project, would I be better suited with a MIG welder (as compared to gas) (within a price range of $500-600)? Are there any suggestions as to "the one" to get? Any help is appreciated. Thanks.
~Matt Segal
Welder Type?
Re: Welder Type?
MIG is OK for stainless provided you get real good at it and are prepared to do a bit of grinding, but TIG is the only one for me. Some very few TIG units have dipped under a kilobuck, but the better ones like the Lincoln models are found on special sale at around $1200.00 not including gas.
MIG welding uses a feeding wire and in all but expert hands leaves a beaded up and balled up weld.
TIG flows like butter and doesn't rely on external filler metal.
I have all three forms of modern welding, GAS, MIG, TIG and don't know how I got along on just one or the other over the years.
I now use TIG almost exclusively on SS and aluminum. I use GAS second most often. Mainly, it is valuable for brazing, and silver soldering. My poor MIG unit is relegated to common steel welding (mostly repair)and is, therefore rarely used.
