Proposed polarity-reversal experiment
DavidHansen
Re: Proposed polarity-reversal experiment
Post by DavidHansen »
The crude experiment I was referring to was the train car reactor core. I think Farnsworth's devices are beautifully elegant, not crude. The solid palladium (or palladium-plated) target is a good idea. Or, perhaps a spherical palladium screen - recirculation of ions could still occur, so the bombardment would be effectivly greater than if it was a solid sphere.
I still wish to know which of Farnsworth's machines was involved in this spectacular runaway.
David Hansen
Brian McDermott
Post by Brian McDermott »
I think it was the Mark 2 prime, which is the one seen in all the "warp core" images.
The mark II prime was Gene Meeks machine and was a T + D machine. It never ran away. The runaway machine was not identified to me though I have surmised that it was the mark II operated by three people present. George Bain, (engineering head), Fred Haak, (Systems Engineer) and Jim Fisher, (technician).
Adam Szendrey
Real name: Adam Szendrey
Post by Adam Szendrey »
Is it known what material did they use for the cathode in that runaway device? Was it tungsten?
Adam
The grids used by the Farnsworth teams were all stainless steel.
Adam Szendrey
There are at least two facts againts the cold fusion runaway idea.
One is that in "conventional" CF cells there is no neutron count increase (if there is any). But in case of a runaway there is a massive neutron blast.
Second is that i've never heard of CF experiments using stainless steel.
Any ideas?
Adam
I think there are two different runaways here and we are doing an apple and oranges comparison here. CF runaway for the most part appears to be totally aneutronic. Fusor runaway appears to be good old hot fusion doing something weird.
I realize that some here wish to try and boost or insure some sort of runaway by trying CF related materials in a fusor grid. This is laudable, but linking the two forms is out of line just for the moment. CF is found to be a surface effect in a much kinder, gentler environment. Nothing in the fusor is kind or gentle. Still, all this is worth a shot especially to those looking to push the envelope or grab at straws depending on your obervational position.
Adam Szendrey
What i meant was that there are at least two things againts linking the fusor runaways and CF runaways.
Adam
