Fusion reactors by energy quotient
- Steven Sesselmann
Re: Fusion reactors by energy quotient
Jon Rosenstiel has just pushed his fusor a little harder and pushed the benchmark up for all of us, his best run has been improved from a Q of 8.09e-9 to 8.42e-09 (a 4% improvement).
See Jon's post here;
viewtopic.php?f=6&t=2899#p12409
Here is how it calculates out on my Bubble calculator...
http://www.beejewel.com.au/research/fus ... ulator.htm
Calculations
Power input: 1680 Watt
Neutron flux at detector: 1.07 e3 n/s/cm2
Neutrons isotropic 1.21 e7 n/s
Total D+D fusion reactions 2.42 e7 fusions/s
Proton energy (3.02 Mev) 3.65 e13 ev/s
Neutron energy (2.45 Mev) 2.96 e13 ev/s
Triton energy (1.01 Mev) 1.22 e13 ev/s
Alpha particle energy (0.82 Mev) 9.92 e12 ev/s
Total fusion power 8.83 e13 ev/s
Total fusion power (converted) 1.41 e-5 Watt/s
Q = Energy out vs. energy in 8.42 e-9
Calculations
- Steven Sesselmann
All,
The University of Wiscounsin have good data of their best run in their Homer IEC fusor, this fusor is large in comparison with the amateur fusors, and they are feeding it with plenty of juice.
http://iec.neep.wisc.edu/results.php
I plugged the data into my Q calculator and here are the results.
Calculations;
Power input: 14250 Watt
Neutron flux at detector: 7.64 e3 n/s/cm2
Neutrons isotropic 2.40 e8 n/s
Total D+D fusion reactions 4.80 e8 fusions/s
Proton energy (3.02 Mev) 7.24 e14 ev/s
Neutron energy (2.45 Mev) 5.88 e14 ev/s
Triton energy (1.01 Mev) 2.42 e14 ev/s
Alpha particle energy (0.82 Mev) 1.97 e14 ev/s
Total fusion power 1.75 e15 ev/s
Total fusion power (converted) 2.81 e-4 Watt
Q = Energy out vs. energy in 1.97 e-8
Calculations;
- Steven Sesselmann
Ben,
Your fusor is on the Q list, and I am confident that you will get better numbers as your fusor burns itself in (for lack of a better expression
When you report a better run, I will move your fusor up the list.
Thanks, Steven.
Hopefully I will get better numbers, after I get another power supply, which hopefully will let the fusor "burn itself in" while not "burning itself out"!
Ben
Ben
- Steven Sesselmann
Richard has a good run with FUSOR IV and moves up the list.....Watch out Jon!
Jon's 10e7 super run is quite safe. I pushed fusor IV pretty hard and probably came close to arcing my insulator, but thankfully did not have that happen. I am right at the limit of my supply and hardware capabilities.
It is a good thing that fusor IV was not damaged in the record run as I have 20 folks from the Virginia chapter of the American Nuclear Society due to come over tomorrow evening to see the fusor in action. I am not planning on ramming the coals to the device the way I did for the VPI students.
- Steven Sesselmann
As we have had many newbies lately and not so many reports of fusion, I am pushing this post up into the recent threads, and hopefully inspiring some new reports.
The list at the head of this thread, is a list of fusors in order of efficiency. The purpose of the list, is to identify which fusor designs work better.
Submit a detailed report of your fusors best fusion run, preferably with "bubble proof" results and your device/fusor will be added to the list.
Don't worry if your results won't place you at the top of the list, simply doing fusion is a noteworthy achievement, and you deserve to be on the list. Knowing what makes a fusor perform badly is just as important.
It is good discipline to keep a notebook with detailed records of all your experiments. record details such as, date, build version, pressure, voltage, current, time, neutrons etc.. A simple exercise book with a few columns will do the job.....
Good man Steven! Push the important stuff forward lest it remain in the doldrums. This certainly deserves to be tended to by new fusioneers who will, hopefully, log their data in the required detail.
- Steven Sesselmann
Thanks to Tyler Christensen, I have regained my editing rights so I can maintain this page.
Today I have added Daniel Firth's fusor to the list, which is a standard Farnsworth fusor, and a very nice one I might add, click on the date in the table above, to find the original post that describes his fusor run.
Daniel and others, please note that I am more than happy to edit the table above with more recent data, to reflect improved performance.
Don't forget, the objective of this survey is to build a database of what works and what doesn't.
As Chris Bradley has often said, any revolutionary new fusion reactor design with dramatically improved efficiency, will show improved efficiency from as little as 5kV
Keep at it...
Keep at it...
Everyone must remember..............If your efforts are to be cataloged by Steven, you MUST give adequate information or he can't figure out what you've done. This means full, accurate metering of voltage and current from the supply and a good neutron count based on an accepted neutron counting method.
For more info on what is demanded see:
viewtopic.php?f=18&t=7893&hilit=faq#p55852 -re: faq
- Steven Sesselmann
Hi Guys,
Some of the more recent members may not have seen my fusor list here and not many have claimed a listing recently. Thanks to frank I now have editing privileges and will start maintaining this list again. See the first post in this thread for the conditions required to claim a rank for your fusor.
viewtopic.php?f=6&t=2826&p=12336#p12336
- Bob Reite
- Real name: Bob Reite
Ah! My best fusor run would be between #4 and #5 on the list as it is today:
Bob Reite's standard fusor.
Standard fusor.
22 Oct 2014
Q = 2.49 e-9
40 KV @ 7.0 mA
42 bubbles over 5 minutes
33 b/mRem
viewtopic.php?f=18&t=9689 Run #3
Standard fusor.
22 Oct 2014
Q = 2.49 e-9
40 KV @ 7.0 mA
33 b/mRem
- Steven Sesselmann
Thanks Bob,
Nice work, you are now on the list.
- Steven Sesselmann
Announcement,
July 2016 Andrew Seltzman's superb effort with his Mark3 fusor has been added to the list in position 3, technically it should be number two on the list since the benchmark #1 on the list is not an amateur effort, in any case I have a feeling Andrew is not giving up just yet.
- Real name: Andrew Seltzman
I don't see Carl Willis' "Carl's Jr" fusor on the list:
from a run in 2008: 75 kVDC, 12 mA, 12 mtorr, > 2E+06
This would equate to a Q of about 2.6e-9
https://carlwillis.wordpress.com/2008/0 ... -carls-jr/
Andrew Seltzman
www.rtftechnologies.org
- Steven Sesselmann
Andrew,
Okay I have added Carl's documented run to the list, I have no reason to doubt his figures. Normally I add people to the list by request, so if anyone else has a best run they want added to the list, please give me the link to the run report.
