Gas cylinder thermal expansion
- Andrew Robinson
- Real name: Andrew Robinson
Re: Gas cylinder thermal expansion
WOW It's so white and empty. You have definitely added lots since 2004
This was early in the construction phase. I attach the late 2004 image of the finished, working system. Save for a few newer instrumentalities, it is virtually the same. By this time I had made most of my early mistakes in system assembly and design and had learned from them.
