What will happen if the fusor run in 170kV?
Real name: Dennis Brown
Re: What will happen if the fusor run in 170kV?
Post by Dennis P Brown »
Just hope he understands how to make good shielding (for himself and others who may be near if this isn't in a proper lab) and has proper radiation (read x-ray) detection equipment.
RealBorg
Real name: Thomas Zehetbauer
Post by RealBorg »
Proper shielding of the high energy x-rays would be an absolute necessity.
This means not only shielding the direct path between the operator and the device as most people here do, he also needs shield against x-rays scattered back from the walls above and behind the fusor. He should really learn about radiation protection before trying to operate a fusor at these levels.
Tom
J Y Zhang
Real name: J Y Zhang
Post by J Y Zhang »
hi,John
I'll show it to him. Another question,where did you buy your Pressure gauge? I've looked for Pressure gauge which can measure 10^-5pa.
Bob Reite
Real name: Bob Reite
Post by Bob Reite »
I have observed backscatter from my system if operated at 50 KV (still just doing air, once I get off the computer it will be back to building the gas handling system). I'm probably going to have to give up on the mirror route and use a video camera (found a "cube camera" that I forgot that I had) and totally shield the viewport area to get rid of the backscatter.
Post by John Futter »
Zhang
just look for cold cathode ionisation gauges on ebay there are plenty there
Edwards
Phillips Granville
Varian
Leybold
Dynavac
10^-5 Pa = around 10^7millibar
all make these
