Screen over turbo?
- Real name: David Kunkle
Screen over turbo?
Hi all,
Wondering if I really need a screen over the opening to my turbo. It's getting mounted very close to the top of my 20" cylindrical chamber on a 90 degree elbow. I already have a piece of #30 mesh SS screen that I was going to weld over the 4" opening to the elbow inside the chamber. I could see it being necessary if the turbo was hanging from the bottom of the chamber. I figure, worst case, any debris should fall straight down. Wondering if it's worth the loss of pumping speed vs. the odds of some object winding up in the turbo being mounted so high?
Ernest Rutherford
Ernest Rutherford
Re: Screen over turbo?
A screen has a lot of advantages and really no dis-advantage so why not? As someone who discovered the hard way (a glass tube scattered under vacuum putting small pieces of glass into my turbo (luckily not running) - got most out and it is running again), you never know what might fall in. The cost to replace a turbo if the blades hit junk while spinning is very high and the screen is trivial to install ahead of time - why not?
- Chris Bradley
Assuming you are implying you have one with the turbo, leave it on. As well as being protection from particulates, it is a last defence against any plasma discharges that might enter the vacuum stream and find their way to any electronics down-stream.
Pumping speed is not critical for a fusor since most of the time it is running under zero or almost zero input gas load at pressures well above the ultimate pressure of a turbo. In fact, you will probably want a choke valve between your turbo and chamber so you can have high enough chamber pressures without needing to flow 100's of SCCM through the system.
A screen will only lower the pumping speed by a few percent. Use one if at all possible.
Last edited by prestonbarrows on Mon Oct 20, 2014 10:35 pm, edited 2 times in total.
- Bob Reite
- Real name: Bob Reite
I have a screen over my turbo. Unless I'm experimenting at a really high flow rate, I have the turbo running in "Standby mode" at 2/3 of rated speed after I get the chamber pumped down.
Leave it on
unless you have a limitless budget and plenty of turbos in stock
Looks pretty well unanimous. I'll have the screen welded in over the entrance to the elbow. Didn't realize it would only cut pumping by a few percent, so no reason not to put the screen in. Thanks guys.
Ernest Rutherford
Ernest Rutherford
In molecular flow, the pumping speed is ideally proportional to the pump inlet area. If you block half the inlet, you get about half the pumping speed.David Kunkle wrote:... Didn't realize it would only cut pumping by a few percent...
So if your screen has, say, 50 square centimeters of open area for every 100 square centimeters of mesh, you will loose about 50% of your pumping speed. Most screens are something around 90% open so you will loose in the ball park of 10% maximum pumping speed. But again, pumping speed is not that important for a hobby fusor.
It is usually more important to make sure you have a high conductance path to the chamber (wide short pipes). Especially for smaller turbos, it is easy to choke their max pumping speed by trying to pump through a long bellows etc.
Looks like my #30 mesh screen has about 45% open area. There goes 1/2 my pumping speed which I will need down the road. Looking at other screen available on ebay, 8 mesh is 60% open area. Preston said most screens are around 90% open. Am I looking at the wrong types? Anyone know where I can get the right type? Thanks.
My turbo didn't come with a factory screen. When I looked at some of the usual pump suppliers, the prices seemed pretty ridiculous. They seem to use 28 mesh on the larger sizes and 74 mesh on the smaller fittings. The 28 mesh looks like it uses similar wire sizes to my 30 mesh.
Ernest Rutherford
Ernest Rutherford
According to the manual for my Varian 301 it says the screen will drop throughput by 10% and that is a pretty fine screen.
Leave the screen in, if something were to get into it some how it would be bad. The other day a friend had a leybold maglev just suddenly grenade, it ripped itself of the mount to the chamber. Same thing would happen if something got sucked in it.
