I bought the "D2O" from the Internet. Each bottle has 0.5g "DO2".It is very expensive and small.It took me "100RMB(16.34 dollars)" to buy it from "TaoBao"
I am going to make the deuterium with the "D2O","Na" and"AI". I am going to displace the "D2O" with the "Na" and displace the "NaOD" with the "AI"
The "D2O" from the Internet
- Real name: å½è¯‘锋(peng yi feng)
- Andrew Robinson
- Real name: Andrew Robinson
Re: The "D2O" from the Internet
That's great that you were able to get your hands on that. I would caution you to do some serious reading first though before jumping in and making purchases. You may find alternative ways of reaching your goals. Some may be easier and cheaper.
- Real name: David Mitchell
I'll second Andrew's advice. Find out what other members have been doing regarding deuterium production, (and other fusor aspects) before shelling out cash. The price you paid for such a small quantity of heavy water seems excessive - you should be able to locate a cheaper online supplier. The sodium reaction with water(from experience) is violent, and a health hazard. There are more peaceful methods of releasing the deuterium. Some members use fuel cells to dissociate the D2O, which is a safer and cleaner method. Whatever method you use, you'll need to send the deuterium through a drying chamber to remove moisture.
