NIM Bin Power Supply's
- Real name: Lawson Boucher
Does anyone know if you can mix and match NIM Bin Power Supplies? Like using a TENNELEC Power Supply on a Canberra NIM Bin?
Re: NIM Bin Power Supply's
Yes
There are about four bin makers still in existance.
NIM is a standard
only caveat is that some bins do not have the +- 6 volt rails
NIM is a standard
Ok thank you! And yeah on some bins ive been seeing 6 Volts not supportedonly caveat is that some bins do not have the +- 6 volt rails
In general, the 6V was for early germanium xistors and early RTL, DTL and TTL logic. Modern bins rarely even support the +/-6v buss! If the buss is there, the +/-6 volts almost never is! why?The buss is most often powered by post-purchase, plug-in, +/-6 volt accessory supplies. These supplies usually are powered by the 120 volt AC buss and can supply 3 amps or more on the buss.
In today's world, there is just no need for +/-6v unless you unwisely purchase an older bin module that demands it.
Modern 5 volt digital circuitry in any modern module is either handled by a linear three lead 5V regulator on the 12 v buss or a small 5 volt, 90% efficient switcher on board working off the 12 or 24 volt buss.
