Caden Burkhardt-Fusor Progress
- Real name: caden burkhardt
Re: Caden Burkhardt-Fusor Progress
8/31/20- bought TC gauge and readout
- Real name: Robert Virkus
Hello Caden,
You have probably thought through all the safety issues but if you have not, please make sure you don't accidentally generate some dangerous X-rays!
Thanks,
Robert
Thanks,
Robert
As for x-rays, as Richard points out - distance is one's friend when the fusor is running.
Robert
While we are at it
could you please edit your profile so that you are Robert Virkus as the rules state not just Robert
Thank you
While we are at it
Thank you
I was doing an X-ray experiment while a student in physics and I was deeply engrossed in thought and I just walked right around the shielding like an idiot right up to the device without thinking when it was full on so I know it's possible to defeat safety protocols.
Running a fusor at home requires essentially zero margin for error when it comes to high voltage; sure, the x-ray radiation is dangerous (and need not be with careful design) but a short exposure is highly unlikely to cause long term health issues, much less death. Not so with the power supply - one mistake and death is instantaneous. Rethink doing this if you feel that you cannot follow strict procedures without failure.
9/5/20-Tc gauge readout arrive-analog with two set points
9/11/20- Tc gauge arrived
9/13/20- Hooked up the tc gauge to my chamber and ran a preliminary vacuum test. I got my chamber down to 100 mTorr I'm yet to do a plasma run with my new vacuum gauge but I hope to do so, record the data and compare it to the visual vacuum gauge FAQ
Is your chamber only reaching 100 microns or is that the gauge giving an inaccurate reading? Try the gauge just on the pump head and that will tell you: first, if the gauge is likely accurate; second, whether your chamber is leaking or not.
