Fusor construction questions
Joshua Turbyfill
Real name: Joshua Turbyfill
Re: Fusor construction questions
Post by Joshua Turbyfill » Sat Feb 01, 2020 4:57 pm
Okay I'll build that then. I read in one of the faq's that arcing can be an issue. I have a thick copper wire wrapped around the main 8" cross which goes straight to ground on a wall outlet. Is there any risk of arcing destroying any of the equipment (Turbo, turbo controller, vacuum gauge, etc)? Also is there anything else I need to know before operating a 2.75" fusor?
Currently I've got a table about 12' from the fusor which has the variac for voltage control, a laptop for neutron monitoring, and a big screen showing 4 different cameras mounted on the reactor. I was intending to remotely operate it. Since the needle valve which admits deuterium and the bellows valve are manually operated, will I need to run the fusor standing next to it?
Post by Richard Hull » Sun Feb 02, 2020 8:56 am
Wrap no bare wire around the cross for a Ground!! A proper ground is a copper tab or solder lug with a hole the size of one of the bolt threads placed under the bolt head and torqued down as part of a flange within the cross end plates. A wire is then secured to the copper lug mechanically and then soldered to it. This and this alone, is now a proper ground connection to the chamber. It may then be taken to a star point ground and the star point then connected to the mains ground.
The star point ground is explain in the power wsupply forum FAQ's.
Joshua Turbyfill
Post by Joshua Turbyfill » Mon Feb 03, 2020 7:14 pm
I'll change that then. Heres the new fusor. What do yall think?
Post by Richard Hull » Mon Feb 03, 2020 9:11 pm
Beautiful and very impressive. We look forward to reports on operation.
Post by ian_krase » Wed Feb 05, 2020 10:42 am
Looks pretty impressive.
Have never seen a fusor wearing a crucifix before, even if I did pray the rosary during pumpdown.
Post by Dennis P Brown » Wed Feb 05, 2020 1:49 pm
I see you have two possible fusors chambers (a large diameter, and small); nice economy on pumping systems. Very professional system. If the cross is silver, are you trying activation, maybe?
Post by Rich Feldman » Wed Feb 05, 2020 5:35 pm
I applaud the wireless connection of probe to HV feedthrough terminal. Did you modify the probe to read negative kV?
Joshua Turbyfill
Post by Joshua Turbyfill » Fri Feb 07, 2020 2:05 am
Thanks guys. Haha no its not for activation I just thought it would be a nice touch.
Yeah so the big chamber I'll use as a demo fusor since its big and looks pretty cool with the turbo in the background.
For the probe I think someone told me to open it up and take the two wires on the inside and just swap which terminal they go to. That did the job.
